Hey fellas just thought I would post up my stats and my first outings results.
So Ive just had the engine built in my 32 GTR, pistons, rods, nitto oil pump, poncams, 2860-5s, plug in ViPec blah blah. Anyway we only had time to tune it 15psi and spun out 300kw. Still a very basic tune and haven't touched cam timing yet. Anyway last wed night i dragged the car down to WSID in hopes of cracking into the 11s. First pass went 11.55 at 120, 2nd pass went 11.65 at 120 ( bogged it on the start) and the final pass I let all tyres down to 25psi and reeled off 11.35 at 121.79 with a 1.7 60ft. Wheel spun the whole of first so still some in it as is. In 2 weeks it goes back to rape it for what its worth on pump then doing a tune on C16. Will be interesting to see what its got in it with a full tune.
https://www.sau.com.au/forums/topic/418123-first-time-down-the-strip/
    • I was more thinking so it doesn't flop around as much rather than for rotating it. Once you have the balance right, it should rotate well enough, depending on how much resistance there is on the pivot. I think you said the pivot point was on a bearing though didn't you?
    • You can get them with the worm drive rotator but I was too tight to pay another $250-$300 so manual labour it is! I don't think it will be too hard to rotate though.
    • Sag as in the windows start to slowly open themselves, or they're just slow to go up/down with engine off?
    • It looks like it needs a big worm gear drive on it to control the rotating, not a few sloppy pins!
    • As Duncan said, first there was OBD, which few cars used, then came OBD2.   Now an interesting point, OBD2 isn't even for what you want to do. OBD2 is for emissions testing. There is some sensor data on OBD2, but it's up to the manufacturer what they're putting on it. Most scan tools operate on UDS, which like OBD2 is a standard built on-top of CAN. UDS specifies how to structure a message, what very limited things mean such as "read memory address" but it does not specify what is stored in which memory address, that is all up to the manufacturer. You either a scan tool compatible with that vehicle, or to know how to reverse engineer all the data, which can take a VERY long time and a lot of vehicles to get it right. Oh and then the manufacturer does a firmware update and changes what's where... Ask me how I know that as fact Oh, and by the time you've got the scan tool that supports all the manufacturers stuff, well, you're back at "But a consult cable and the Nissan software" The main difference being most manufacturers software these days works with the same hardware readers, as the readers are built to support J2534 which is another standard for how the PC communicates with the tool to make it do specific things on the car...
