Hey guys up for a regrettable sale is my rb26 engine, it is out of a 96 vspec gtr33, I got the engine out of the crashed 33gtr and spent a lot of money on it, how ever after a lot of money spent, funds are running out and the engine conversion I was going to do is no longer possible. So my Loss is your gain! Almost all the parts are new or near new and only the best parts have been sorced and used.I also have a very low k rb25box and drive shaft which I was wanting to sell with the engine as a complete set, it also comes with a brand new extreme race 5 puck clutch brand new still in the box,(pics up soon waiting for mechanic to send them threw) it will come with a custom made sump on it just to protect it, the sump was made for my swap i was going to do. Will sell separate the engine for (5500) but was wanting to sell as a pakedge for 8k, or 2200 for the box and $800 for clutch have receipts for the work done. the engine is currently in a preformance shop in Brisbane, contact me if interested and want to go look at the engine and do any test ect, buyer must pick up or i can help pack it up ect. no scammers guys just after a fast sale..
the specs are a
*low km recon head
*hks 272 cams
*cp forged pistons
*argo conrods
*new balanced crank
*acl racing bearings
*nitto oil pump
*gates water pump
*gates belt pulley and tensioner
*r34 Zune garret turbos
*hks stainless dumps
* 700cc denso injectors
*nitto clear timing cover
*tommi fuel rail
* spitfire coil packs
*all new welsh plugs,gaskets
*new painted came covers
*greddy intake pipes
*nismo fly wheel
*fuel reg
*speed flow fittings and braded lines
all rubbers where replaced
Has air con compressor with it and comes with a box of parts,hoses ect the gear box I bought from a importer with only 80000k on the clock very smooth no crunching at all, any questions please call me on 0418668169 thanks
https://www.sau.com.au/forums/topic/418124-big-hp-rb26/
    • They care about emissions, and cost the most. Save weight where possible, and make manufacturing easier. Less material also let's the engine transfer heat to water quicker, and bring the engine up to temp quicker, better for emissions and getting them past their warranty period.
    • I was under the impression the reason why OEMs are going with solutions like relatively thin "right-sized" cylinder walls with technologies like PTWA and open deck is because they care a lot about whatever marginal knock margin benefits they get from that vs the structural rigidity benefits of a closed deck block and thicker cylinder walls. I also see some weird stuff like plastic inserts in the water jacket around the cylinders to try and equalize cylinder wall temperatures. re: the PRP blocks and heads at the end of the day it's hard to know what is and isn't going to work there, just have to see what the initial buyers say about it.
    • Which is why I didn't mention that hardness testing, and specifically mentioned the bore and deck thickness testing. Yeah, not really. The bore temperature will be a lot more even around the top half inch or so, where the material distribution is dominated by the deck, and which is the only place where the bore surface temperature heating any gas in the cylinder is likely to have any effect on detonation. Think about it. Another inch or so down the bore, you might have a hotter spot. The gas there might get a bit hotter, then the piston rises squeezes that gas away from there at high speed and mixes it with other gas from nearby. Instant dilution of the problem. I'd be surprised if it was an issue at any time other than in racing engines or OEM dev engines being run at the ragged edge of tuning. Say what now?
    • https://dsportmag.com/the-tech/education/engine-tech-material-hardness-testing/ The PRP testing on block hardness I'm not sure how much it actually can be trusted. The thinner cylinder walls on RBs is a bit of a problem vs 2JZ but it really depends on the design goal. Siamesed cylinder bores like a 2JZ cause uneven cylinder wall temps too, which means a bit of distortion induced by that + the hotspot can affect knock margin. Something that actually gives me a bit of pause with the PRP block, whether super thick cylinder walls are going to keep it from being drop-in compatible on an otherwise OEM rebuild.
    • Yeah very valid point. I am waiting for one of the other tuners to come back from vacation so he can help me a bit when the cat is installed again. In the meantime I am going to finish up my polishing and ceramic coating that I have started myself.    N45 Dr Beasley product is highly recommended for a paint primer / polisher. Using this EXO Gtechniq also for the ceramic but next time might use the light serum before hand also. Looks great.
