So I've recently had my Nismo Coppermix Twin plate installed in the GTR and I'd read so much about them being very drivable and stock like.
Now I've only driven maybe 50kms so may be too early and may need bedding in, but immediate impressions are that it is very... very light. Doesn't feel like it will hold power, almost feel like I need to take the booster off to get more feel. But it's very quiet and seems very strong. It's very quiet in neutral or with clutch dissengaged.
Now my question is for those who run one, is it normal for it to cause some driveline judder on gradual take up? My searches are suggesting no, however I have read that this is commonplace on twins. I can drive around it of course by taking it up with more revs, but wondering if I should be looking into replacing gearbox or engine mounts or if this may be considered normal. My old Clutch had a very slight judder only when cold.
What do you think?.
That's what makes the Nismo Coppermix so driveable. It's not filthy heavy like a OS twin plate for example which over time is like kicking a bag of sand over and over.
The first 500-1,000kms it will be a little bitey, it will settle down though. So give it a little while before worrying about minor shudder.
it says that these clutches make noise and vibrations
Yeah just so that when it does make the slightest noise (and it literally is non-existent) - people dont come back and complain.
As the plates get lower/wear they will get noisier, just how it goes.
My only complaints are it's a bit rattly on idle in neutral (clutch out) because of the flywheel, and slips a bit when cold, aside from that it's brilliant, very light to use and bites hard on high RPM take-offs...
Edited by Iron Chef
I've got one and I could not fault it in any way. When it was installed it was very 'bitey' (probably me just getting used to a twin) but I did get it adjusted (dunno what was done) and it was so much easier to use. No noises what so ever. Not heavy. Very user friendly. No driveline shudder under any circumstances.
Have only launched in 2WD mode but it was a 2nd gear start from standstill. No dramas and was really easy to modulate.
Ace clutch. Should be for the money.
Ive got the Coppermix Twin C-spec in mine and have nothing but praise for it. By far the easiest twin plate I have ever driven and at the same time has a real good bite to it. A few of the guys have mentioned noise issues - you can hear it on the odd occassion in neutral however its pretty subtle and honestly nothing to lose sleep over.
Give it about 500km or so of driving (start/stop as opposed to highway kms) before you give it a launch, I guarantee you it will definately "hold the power" ;)
    • Seemed to be good when Jeff owned it but they did a shit job on my car, probably worth a think before spending 10's of thousands of dollars where they might be cutting corners
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
