A lot of people here say these are the equivalent of the HKS 2530 turbos and driving a few cars around the track that mates own in various different tunes would be about right.
All dyno plots are very similar, spool up, lap times, 1/4 mile ET and MPH times are surprisingly similar.
These were running 17 psi before the rebuild and hit hard by 3,800 RPM, 1st gear would light up the tyres as soon as it hits boost! People freak when they see a GTR light up the wheel under acceleration (not dumping the clutch)
Good for about 500 wheel hp these are an excellent balance between street and outright power. I made about 410 on 17 psi which is a good balance as it does not over power the suspension, brakes and excessively strain the engine.
My mods are:
computer
Exhaust
Intercooler pipe kit
Pod filters
Cam gears
These turbo's have NOT been used since the rebuild!
I am located in Sydney but can ship interstate.
$2700 ono or highest offer
Could you please provide either a photo or list numbers from the id tag in the centre of the turbo shaft. This will confirm the turbos as N1.
Sorry to be a doubting Thomas, but there is an awful lot of confusion about which turbo is which & the only way to be sure is to cross check the part numbers.
Cheers
Hope you don't mind, but here's a page of details for the various Nissan turbos for the GT-R's:
http://www.systranbox.com/systran/box?syst...an_f=1086005489
The ones being sold are mentioned as being R33 GT-R N-1 turbo's. I have a set of the BNR32 NISMO turbos and although not fully tuned yet, know they have great potential.
Cheers
Brendan
    • ...just a note of warning, you shouldn't drive it about with the TCU in limp mode with only 3rd gear available ~ apart from the fact you end up sheering the ATF at the torque converter interface, the high clutch in these isn't especially the strongest, particularly bolted to the RB25DE mill...which is likely a 4AX01 box with lighter duty high clutch (the RB25DET got the bigger high clutch)...be careful out there...
    • Hoping to do similar mods to my RB20 once I get it running and reliable again
    • As you're looking at using a Link ECU, then large injectors are not a problem. But there's not really any need to go 1000s on an RB20 unless you're planning >>600HP on E85, which would seem unlikely. There are other options for injectors. The Xspurt ones are available from a number of places and you can get them in the mid 600s and 725cc, which is probably a sensible place to be. These are all EV14 based. If you are not using the stock AFM (at all, which would be the case with a Link) then a large turbo intake pipe to suit the ATR turbos is not an obstacle, so you should use one instead of a highflow. Results will be better.
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
