selling my garrett t51r. 76mm comp wheel and 1.05 exhaust housing. it is ta flange modified to suit t4 flange. twin pulse manifold with v band to dump pipe. will include v band clamp and cut off section of dump pipe with other half of v band flange.
also included in the sale is 60mm exteranal wastegate and k&n filter with 3.5" 90 degree bend.
turbo made 702.5 on my rb26/30 at 28psi. was an absoloute blast to drive. full boost was seen by 4350rpm and pulled all the way through.
any further questions text me 0427852404 or pm
location is toowoomba qld. will post at buyers expense or can arrange local pick up.
chasing $1400 for the whole package, very cheap for big hp. only selling due to upgrading to gtx42 and new turbosmart gate
  • 4 months later...
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
