selling my garrett t51r. 76mm comp wheel and 1.05 exhaust housing. it is ta flange modified to suit t4 flange. twin pulse manifold with v band to dump pipe. will include v band clamp and cut off section of dump pipe with other half of v band flange.
also included in the sale is 60mm exteranal wastegate and k&n filter with 3.5" 90 degree bend.
turbo made 702.5 on my rb26/30 at 28psi. was an absoloute blast to drive. full boost was seen by 4350rpm and pulled all the way through.
any further questions text me 0427852404 or pm
location is toowoomba qld. will post at buyers expense or can arrange local pick up.
chasing $1400 for the whole package, very cheap for big hp. only selling due to upgrading to gtx42 and new turbosmart gate
  • 4 months later...
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
    • I should video mine, will prob do it tomorrow    Between 1st and 3rd, you could fit another two gears. That is how loose and wobbly it is   horrible:(
    • Throws on the FS5R30A in most Nissans of this era are actually quite short and direct compared to any remotely modern BMW with the S6-53 transmission. Those things have throws a mile long with rubbery vague everything. Synchro issues combined with a short shifter is just going to break everything even faster.
    • Only thing I'd add...is on recommendation from a good diff shop, I've used mineral oil in my diff including the race car for years. The synthetics can be too slippery and glaze the gears
