Got some R33 bits and pieces for sale!
-Got three pink label afm! One has pod filter attached.
-Crossover pipe with stock bov.
-Blitz BOV off my R33 gtst and the little bend pipe adaptor.
-Hot Inazma Voltage Stabiliser, off R34 but fits ANY car.
-R33 GTR spoiler, in shit condition $30.
Also might have an aftermarket intercooler for sale, and if you need any of the piping under the bonnet of an r33 gtst let me know i might have them !
Located in Thomastown, Melbourne.
Will post at buyers expense.
Hit me with a text on 0413323385 no calls thanks!
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
