Here's one I tried some AMMO on Matt...personal project I've been working on, I spent the best part of three days with the polisher on most of the major panels...but bumpers ,mirrors are too faded and will require repainting though when I get some time so i wont to bother show pics of them...Unfortunately with the lighting conditions of my carport and the 23 yr old paint, its near impossible to get every scratch out...but its close ...
Has a few layers of skin and 1 of creme atm, but i think my favourite so far has to be the hydrate.....its very enjoyable to use for everyday detailing duties :)
Picked up some IronX a couple weeks back, had heard some pretty good things about it and wasnt disappointed!
Start with some pretty filthy wheels
Spray and leave for a few minutes
Then clean off
And finished with some Poorboys wheel sealant and also Poorboys tyre gel
  • Like 1
  • 1 month later...
Pretty much my first real attempt at detailing and polishing, did it on my new home respray job on my track car.
Used a super cheap DA polisher then scholls s3 gold for cutting and s30+ for polish as recomended from Antonio from waxit and I'm very happy how well the product works no mess at all! Car was rubbed down with 2000grit wet after spray before cut and polishing it.
post-50426-0-82228100-1395743003_thumb.jpgpost-50426-0-57843300-1395743066_thumb.jpgpost-50426-0-40945500-1395743110_thumb.jpgpost-50426-0-56915300-1395743167_thumb.jpgpost-50426-0-24795900-1395743210_thumb.jpg
Looks like it came up pretty good :thumbsup:
I've got a couple of panels here i've meen meaning to have a crack at but i've got no idea, what process/steps did you use? (sand > clean > primer > paint > clear > sand > polish) etc.
Quick wash and clay, followed by testing out Mothers Mag & Aluminum Polish on the lip. Came up heaps better but definitely more to go. Spent probably 20 minutes just on the lip of this one, need a hell of a lot of elbow grease.
pg[/url]
Process was basically get thd body dtraight since it was completly damaged both sides so alot of oxy and body filler lol but then it was final sand , primer, 800 grit sand, fill any holes with putty, sand putty with 400, then primer over putty areas, sand 800 again, paint, then sand 2000 , cut, polish.
I didnt use a clear since its a solid colour and also its going to be constantly repaired and touched up so makes it easier with no clear. In saying that i consoder my process a rough job if you want to go step further after paint sand down with 1200 then 1500 then 2000 folowed by cut polish will give a perfect finish but takes considerably longer since that last sanding process takes the longest.
Edited by boostn0199
C'mon dude where's the photo of your reflection in the paintwork....anything can look shiny from a distance. :rofl:
loll kind of ran out of time and and no good lighting at the time ended up finishing the job at like 4am took those couple of pics then onto the trailer and drift event next day, now its dirty again, will get some closeups after i wash it next time.
Hi Nicr4wks,
I was running with the distribution of AMMO in Australia.
Unfortunattly when it was first released we were not seeing a high enough volume and shipping was too expensive for our volumes.
I would suggest that the cheapest option would be for you to purchase directly from the ammo website.
You will find that the cost of the suff online is the same price if not cheaper
Cheers,
Matt
www.upcd.com.au
Hi, I did not take any before shots , this car was in a garage for 5 years and I think it must have had holes in the roof, the water etchings were really deep and took forever to get the crap out.
Going to wax it when it get it back from the workshop :yes:
    • If it's magnetic what is stopping you from using a magnet on a thin wire from fishing it out?
    • Those 2 solenoids in that assembly I mention, are the PWM solenoids for torque converter lock-up clutch & EPC (line pressure control) ~ when most folks hear of 'solenoid failure', the tendency is to think electrical failure...but fact of the matter is, especially wrt the EPC solenoid (which is moving/running all the time), you can have an electrically 'good' solenoid, that's absolutely broken/worn out mechanically inside...ie; valve plunger return spring rubbing against spring retainer plate, lowering preload pressure.. ...and the solenoid armature extension limit spring wafer with bad wear/broken off petals... ...and if there's ever been any metal flying about, damage to the valve plunger end itself... ...the stuff one never really sees, unless you go the whole 10yards trying to answer the question "why is my line pressure screwy, but TCU isn't flagging any EPC solenoid fault?"...and carefully dissect the solenoid. Worst (and most probable) scenario is when the plate spring petals break off, they get held by the magnetic flux, get mashed up by the armature into little bits, which end up in the space between the armature & shading core bore, and things get stuck or randomly jam up, and your line pressure goes flat and doesn't change...and the TCU never sees it, as it doesn't actively monitor LP... ..then it gets into insidious land, if you end up with lower than expected line pressure...lets say high clutch..and the lower pressure causes it to slip ~ when I say 'slip', think say 2000rpm on the drive plates, and 1800rpm on the driven plates, because the slip is making them under-rotate by 200rpm ; you get all the usual nasties like heat and band/clutch wear, but even if it's only 20rpm slip the same thing happens...and... you'll hardly ever pick this up driving the thing with the torque converter active as it effectively masks these sorts of slippages that are line pressure related ...(the newer TCUs can detect clutch slip rate)...just  FYI as it were...
    • There's nothing that some paddle pop sticks and extra cable ties can't fix.
    • Hey guys, so Golebys has good prices on Bosch injectors, and also sell an adaptor to go from 1/2 length injector to standard with the Nissan 10.5mm top seal.  Does anyone know if that adaptor is to suit the 14mm or 11mm injector tops?  And re. The bottom seal, to suit my standard RB20 intake, would I be right in saying I can just slip the 14mm square section O ring over the bottom of the new injector and done? Thanks in advance guy, Cheers, Rowdy
    • F my life. I was changing the oil on my R32 GTR today as usual and ran into a bit of a snag. I drained the oil out and was getting ready to finish the job by tightening the drain plug, however The stupid magnetic oil drain plug snapped in half, right at the magnet part. After about an hour of trying to remove it, I used a drill bit, which unfortunately pushed the magnet all the way into the pan, and just leaving the hollow threaded part of the bolt remaining. I was able to remove the hollow portion of the bolt from the oil pan with some pliers but the magnet is still in there.  So, the question is, should I drop the oil pan to get the magnet piece out, or is it okay to leave it in there? I really dont want to drop the pan, i'm about to go nuts.  PSA: Do NOT buy a BLOX magnetic drain plug. This is the one i had.    https://bloxracing.com/products/magnetic-oil-drain-plug-m12x1-25mm?variant=37131252859052&country=US&currency=USD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gad_source=1&gclid=CjwKCAjw47i_BhBTEiwAaJfPpgti1D2JwO7TDuMpXuqeQPCuIQSAfwxpWQH5rF9MD7sm5SCZDWLR_RoC_YoQAvD_BwE
