Time to sell my beloved FPV F6 Typhoon in Mercury Silver. The mrs wants to buy a block of land together so the money I get for this will help towards my end of the bargain. It's in pretty damn good condition and well looked, the car has been clear from accident's and has no encumbrance owing on it. Comes in the ZF 6-speed auto which is driving very well, no leaks or anything like that from anywhere on the car. It really is extremely clean and now comes with a full year registration
I have just fitted up a brand new set of 20" Silver Agent STAGGERED wheels and tyres, with a whopping pair of 275's on the rear for premium grip and safety. An original XR8 bonnet has also been fitted to it, so there is not much left to do aesthetically. The front and rear brakes were recently replaced costing over $1,800 so you're basically getting brand new Brembo's to go with it.
Other than the wheels and XR8 bonnet, the car has just had $3,000 spent on mild performance goodies. Just had a set of 90lb injectors fitted, a high-flow catalytic converter for better breathing, a Plazmaman intercooler, Bluepower CAI and a custom tune, pumping out 302KW at the wheels a mild 13psi. Comes will full service history and the most recent service done at Bluepower was a performance service, achieving great results.
The car really has no faults at all so it will pass any inspection and roadworthy by anybody's standards. Happy to provide roadworthy and undergo any sort of test. No time wasters and low-ballers please. The car is extremely clean inside and out, is at an awesome price of $21,990, I have a little room to negotiate as I do need it gone, but no swaps please. A genuine sale
Can assist with transporting to interstate buyers
Contact Manny on 0488582587
https://www.sau.com.au/forums/topic/418213-bf-fpv-f6-typhoon-with-300rwkw/
$21,000 FIRM, no swaps either please
Anyone that knows these kinds of cars, knows that 302rwkw with these mods is impressive, and a great point to start throwing more supporting mods to. The wheels are staggered and has 275's on the rear so the grip is there, the genuine boss bonnet is already done, the brakes have recently been replaced
The car is basically done, for someone to drive as a daily and have a 300rwkw beast. Come take it away
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
