I thought a random thread should be created to post up anything and everything that you create with PS. I know I randomly learnt something new (like i did on the weekend) and want to post it up.
Feel free to give constructive advise - but its not intended to be a critic forum.
Sticky?!
https://www.sau.com.au/forums/topic/418216-photoshop-creations/
I'm not a PS noob, but like alot of people I have only learnt what I have taught myself with PS. I have been asked by a good friend to create her 30th invite - and she had an idea of what she wanted (a pretty cool invite from some marketing genius overseas). So I initially thought of re-creating it all from scratch, and it has a 'sparkler' type writing at the top. I went searching on how to make it, came up short but did come across a cool neon/sparkles type type that a utube vid explained in great details how to create. So I played around and created the below. Naturally its useless - just a laugh really. And it taught me something new - using the RGB selection to create a selection area, and then how to turn it into a path selection blah blah. Quite a shnazzy effect IMO.
Edited by barraspalding
  • 3 months later...
  • 1 month later...
  • 4 months later...
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
