My Stagea has a random TPS error that triggers limp mode and was hoping someone could point me in the right direction with regards to troubleshooting the problem. This is my first fly by wire car, so TPS issues like this I am foreign to.
From what I understand the M35 Service Manual isn't available in English but the V35/G35 manual is a good reference for this sort of problem.
https://www.sau.com.au/forums/topic/418225-m35-tps-troubleshooting/
Best idea would be to try to borrow a working unit from someone, and try that out. If that works, grab one from the wreckers off a V35 / Z33. I think they are the same. But watch out for any unit that has a hole drilled in the plate.
I don't think there are any replaceable parts within the unit itself. But someone will correct me if I am wrong.
I tried to rip a throttle unit apart to clean the TPS carbon tracks but i'm fairly sure it failed. They are definitely not a serviceable part.
Seeing Nissan want $1800 for a new throttle unit and these are failing like hotcakes I would grab any second hand VQ throttle you can get. A 350z/V35 one will fit, I am running a VQ25DD throttle at the moment due to the same fault.
If you need a hand with clearing the codes, resetting the idle or changing the throttle over, a quick search and you will find the information on here. Otherwise PM me if you need someone to do the work for you.
Thanks for your help guys, I'll try source a VQ throttle and give it a go. $1800 seems abit steep lol, a quick search on Ebay and I've found a "New * GENUINE * Nissan 350Z Maxima Throttle Body" with TPS sensor for sub $250
Edited by stealth01
Post up a link to seller, or is it just a single unit?
Yes, whilst I didn't have a Z33 TB, my old VQ25det Stagea had a V35 (VQ35de) throttle body on it without issue.
So between Scott and I, that would mean that 350z, M35 and V35 throttle bodies all fit.
Prossibly J31 Maxima as well although I have not tested this.
What does the seller mean when he says "For your peace of mind this part comes with a 12 month manufacturers warranty at least."
...at least?
I reckon he's bought heaps of these at a clearance sale & will swap any faulty ones for as long as he still has stock.
It's more likely to be the throttle body but the pedal could be the issue. As it's just a glitch that causes the limp mode it is very hard to measure voltage or resistance issues, easier to swap the parts out.
Just to add to this, it seems that when it goes into limp mode, I can turn the car off, tap the pedal input sensor on the pedal afew times, start it up and its fine...
Is the pedal input sensor as interchangeable as the TB seems to be?
Jap manual is on here if you want it, can be good for pics and some use with googly translate.
http://www.skylinesaustralia.com/forums/topic/341609-stagea-workshop-manual/page__hl__manual__st__20
    • 99.9% of them are viscous diffs. The 0.01% are helicals. They were only option-able in the series 2, as well. I have redline heavy shockproof in my helical. It seems... fine? I don't think anyone is ever going to know until something really breaks and at that point I'm not sure anyone will blame the oil. I just chose it because it's extremely heavy duty and my car will see not-road-legal duty for it. I've also had sadness with various diff oils in the past sweating out everywhere and/or other 'fun' things, with clutch diffs. Given you have a 1.5 way on the shelf, I'd not even bother with the diff in the car and just get to tinkering with it. I would spend the $90 on oil toward the labor of someone else putting the diff in if time poor even lol.
    • I believe mine is helical and not clutch type. During drifting one wheel was spining as if it was open diff so bought kazz 1.5 way and has sat on my shelf for the past 5 years as I want to learn shiming process and do it myself   in meantime thought I change the diff oil hence post here. So any 75-90?   i am pretty sure r34 are helical not clutch lsd as standard . That is gtt ones
    • Throw between gears are so much that is getting annoying. I have pro short shifter on my mx5 and e36 and love it . Skyline is getting unbearable    would syncro issues and short shifter is no no? Anyone mind explaining a little on why before i buy cube
    • No. Well, some people "seem to use redline shockproof in the diff". Most do not. I would only contemplate it if you have badly worn CW&P gears. And no. No-one in their right mind has ever put ATF into a diff. Any normal diff/gear oil of the right viscosity will do. Whatever takes your fancy. Castrol, Nulon, Penrite, Redline MT range. Whatever. It's just gears. 75W-90 or 80W-90 is typical. I think that GL-5 is hard to avoid these days, although I think that a GL-4 is probably preferred, given the vintage of the equipment. At least Redline offer a number of GL-4 oils. If you have a clutch type LSD instead of the VLSD, then of course you need a proper LSD oil. Anything from any of the same names above. If you have a helical LSD, then it does not require LSD oil, and the recco is the same as for the VLSD. You don't want the LSD friction modifiers in the oil for a non-clutch type LSD if you can avoid it.
    • You may want to list it up for a little higher - This price is much lower than you may realize. Here you're pretty much selling to people who most likely already have these things on their own rigs. S chassis people eat this stuff up like you'd not believe.
