Hey guys I am located on the Gold Coast, willing to post items at cost or pick up and currently have the following for sale;
(Prices Negotiable)
R32 GTR Passenger seat Immaculate condition, with rail, all movements working perfectly $280
Also have a std R32 Gtst drivers seat laying around in good condition for $40,
polished dished Work Equips 18"x10+28 fronts, 18"x11.5+24 rears $2200 (tyres very poor)
post-44496-0-11981500-1354438815_thumb.jpgpost-44496-0-12466200-1354438830_thumb.jpgpost-44496-0-65374500-1354438835_thumb.jpgpost-44496-0-78718400-1354438841_thumb.jpg
HKS Super dragger 3.5" exhaust cat back to suit R32 chassis and twin front pipe to suit rb26dett will separate or $500ono the lot excellent condition polished cannon 5"
Momo steering wheel in perfect condition, also have an immaculate genuine horn button to fit. Steer wheel $130, Button $20 post-44496-0-95102800-1354439884_thumb.jpgpost-44496-0-94130200-1354439892_thumb.jpg
Pwr FC hand controller $300 late model pwr fc
R32 drivers door control switch board perfect condition $50
R32 GTR front left driveshaft perfect condition, good cond boots $100, also have transfer shaft from gearbox to front diff and tailshaft $100
Rb26 starter motor $60
HKS 2530's $2000 pair turbos only, done 2000kms also have oil drains, lines, std dump and manifolds etc enquire for price
post-44496-0-29139600-1354439251_thumb.jpgpost-44496-0-88160400-1354439268_thumb.jpgpost-44496-0-00615300-1354439288_thumb.jpgpost-44496-0-46621000-1354439293_thumb.jpgpost-44496-0-82637500-1354439300_thumb.jpg
Tein Coilovers to suit R32 GTR and GTS4 $750 very good condition no leaks, heavy spring rates of I think 12kg and 10 kg height adjustable go very low, and damper adjustable, have genuine spanners to suit
post-44496-0-87689600-1358738950_thumb.jpgpost-44496-0-95886400-1358739017_thumb.jpgpost-44496-0-64021400-1358739042_thumb.jpgpost-44496-0-88991600-1358739068_thumb.jpg
R32 Japanese Fibreglass front vented guards good condition $250 with mesh in vents (not cheap local made, these are durable jap guards)
SKYLINE door skirt trims great cond.$50pair
R32 skyline floor mats genuine original $60
RB26 Coil Pack loom excellent condition $100
D1 SPEC racing lightweight nuts in blue x 20 $30
Bolt on fenders 1 pair fronts and one pair rears are roughly 30mm guards with rubber trim and polished capped nuts $120
R32 windscreen trim plastic piece great condition $30
R32 clutch master cylinder clean and perfect working condition $60
R32 handbrake complete, good cond. leather $60
R32 abs model master cylinder, clean great working condition $80
R32 GTR (also fit gts4) ABS module excellent condition no leaks $300
R32 'A' Pillar Trims, left and right side, excellent condition have all clips $30ea
R32 m spec fog lights (can make to suit anything) excellent condition $50
R32 Tail lights $100 pair
Bosch 023 fuel pump custom fitted to R32 fuel pump cradle and sender complete unit $140
R32 boot lid and genuine N1 lip, professionally painted and wing holes filled in $300
R32 gtst front brake rotors, pads and vented slotted discs, excellent condition pads and discs only used for 10000km $250 pair front left and right
R32 GTR front hubs and wishbone complete left and right side, $100ea
R32 gtr (will also fit gts4) gearbox crossmember $40
R32 horn and bonnet catch support $50
R32 gtr rear seatbelts pair, great cond. $60
R32 front strut brace has had part machined out to clear crossover pipe on rb20/25 $30
R32 GTR front transfer shaft, gearbox to front diff, great cond. $80
apexi turbo timer perfect working condition $20
R32 dash surround $30
Rb26 engine loom good condition from r32 late model $150
Names Johnny I would rather you call or txt, otherwise please PM, thanks
0414596256
Edited by slidinr32gtr
Hey mate txted you about the door sill/ kick plates but you didnt reply are this still for sale if yes id like them thanks :)
  • 4 weeks later...
  • 4 weeks later...
    • A few more recent pics
    • full send the cnut, do this   fark the wrapping and/or stick on siet. These guys are the ones to go to: https://www.realthermo.com.au/
    • Just had a look, they don't. Fuelling on the base map is purely alpha-N, and the ignition table is MAP. Remember it's just a base map to get the car moving
    • Hi everyone, I’m Dave from Canberra. Here's a few pics of my 1992 R32 GTST coupe which I imported back in 2006. Only mods so far are HKS Hi-power cat back exhaust, K&N filter, ATC Volanti steering wheel, Pioneer stereo, amp and sub. This was my daily driver up until 2015 and sadly hasn’t been driven at all in the last 5 years due to marriage, work, and kids taking up most of my time and spare cash.As such its in need of a bit of TLC and one of my goals for this year is to get it back to running condition and maybe look into club/historic rego. I’ve joined SAU so I can ask a few questions along the way (although I promise to google Current Problem +SAU beforehand!)
    • From talking to the mx5 guys the NC doesn't actually need bonnet vents like the earlier NA and NB models, due to a better designed cooling system and undertray design There's plenty of them used as street cars and weekend track toys running anywhere from around 170 to 250kw with stock non vented bonnets, I initially was going to get some bonnet vents, but, as they are not actually required, I'll put vents on hold for a while and just monitor temps, though I do need to get something to actually monitor engine oil temps though, coolant temp can be pulled from the OBD2, but the oil gauge in the car is not actual oil temp, it is only a calculation based off coolant temp and RPM ☹️ They do recommend upgrading the radiator, which I have already done with a triple pass, and the only other thing they recommend for a street car is heat management, like I talked about above to protect bits in the engine bay from radiant heat, and to either replace the nearly 20 year old plastic coolant expansion tank, which I have done, or get a aftermarket alloy jobbie for some bling They did also say that if I wanted to track the car on occasion a oil cooler and sump baffle would be required, and as I already have had a sump baffle installed when the engine was out......... I'm going to get a oil cooler with a thermostat....... just in case I do eventually track the car, but probably not, but still maybe...🤪
