Hey gang
I have a bunch of R32 parts for sale. These parts are located in Perth WA but I am willing to ship if the buyer is willing to bear the expense. Parts include:
Passenger and driver side window glass........................120 each
windscreen wiper motor.....................................................60
rocker covers..................................................................100
Rear Seat.........................................................................70
various interior trim and misc parts (visors, mirror etc)....enquire and ill let you know
Dash...............................................................................150
Rear brake discs.............................................................130
Rear brake calipers........................................................120
centre console.................................................................75
tail lights ........................................................................130
cluster surround..............................................................60
Middle rear seatbelt.........................................................25
Stock ECU.......................................................................75
Stock Airbox assembly.....................................................50
Interior quarter trims........................................................75/Pair
Fuel tank door.................................................................25
Pod filter with adaptor......................................................30
Reverse lights.................................................................50/Pair
Contact me on 0420 593 194. There are other bits and pieces in the shed so ask me and I'll have a look. As mentioned above, THESE PARTS ARE IN PERTH WA BUT I AM HAPPY TO SHIP.
Cheers
https://www.sau.com.au/forums/topic/418244-r32-parts-for-sale/
  • 3 weeks later...
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
