(Melb) 217Kw My98 Wrx: Vf22, Pfc, Bc Coilovers, Gd Brakes, Pw Tmic.... Trades Welcome
Make:
Subaru
Model:
WRX
Year:
1998
Kms:
286000
Registration:
OYL-802 (exp. 13/05/13)
Northcote, VIC
Contact:
0431320142 or PM
Price:
$11000 as is, plus $500 with paint repairs, plus $500 with RWC... or swap for car of lower value plus cash my way.
-----------------------------------------------------------------------------------------------------------------------------------------------Engine:
EJ20k. Rebuilt at 241000kms (44000kms old), with reciepts.
Makes 216.9rwkws @ 5569rpm using e85 and 20psi.
Power FC and hand controller, tuned by Pro-Tek Automotive for e85
Eboost street (40psi)
Five-O-motorsports 1000cc sidefeed injectors
Walbro GSS342 fuel pump
VF22 turbo with turbo beanie
Process West TMIC
ASI silicone intake
V4 STI 90mm AFM
K&N Panel filter
90mm PVC intake trumpet on standard airbox
3" Xforce turbo back exhaust, dump pipe heat wrapped, into a Hitech single tip oval muffler
The engine seems to be in great condition and goes very well. There doesn't appear to be any engine leaks or weird noises.
Driveline:
V4 STI 5 speed gearbox and diffs (4.44)
Standard spec. organic clutch
The gearbox seems to be in good condition, with no real grinds or anything. It sometimes feels like it could engage 2nd more easily, but this could be due to worn shifter bushes. The shifter is very sloppy and it's bushes are most likely worn. There appears to be a bit of a leak from the centre diff. I'm very conscious of the gearbox when i'm driving, with no hard shifts or launches.
Suspension
BC BR gold series coilovers (less than 5000kms old)
BC adjustable camber tops front and rear
Whiteline 24mm rear sway bar (standard front)
Whiteline anti lift kit (not fitted)
Street/aggressive alignment by Centreline Suspension
The car handles really well.
Brakes
GD 4 pot front calipers (painted lime green) with standard rotors
Intima SR front brake pads
GD 2 pot rear calipers (painted lime green) with standard rotors
Dogbone adaptors by Mark Smith (cruisn)
Intima SR rear pads
I broke part of the right hand side handbrake assembly when upgrading the brakes, so had to remove it from the hub. My handbrake therefore does not work at the moment. It hasn't bothered me so far, but i did plan to either fix the assembly, find a spare one, or install a hydraulic handbrake. The Intima SR pads are pretty new and are suitable for temps up to 700C (ie. track).
Wheels and Tyres:
16x7" MY98 WRX 5 spoke wheels
Bridgestone RE001 tyres (205/50r16)
Tyres are in pretty good condition, as are wheels.
Exterior:
Standard except for:
MY99 headlights
MY99 grill (needs to be colour coded)
MY99 rear spoiler (needs to be colour coded)
The body is pretty straight, with the odd small bump here and there. The car has been resprayed at some stage and looks pretty good when clean. There is however some area where the clear coat has blistered. The roof has completely lost it's clear coat. The boot has a blister of about 20x20cm and the rear a-pillar has one of about 7x20cm. I've also just added a MY99 grill and spoiler, and these have just been quickly rattle canned black. For an additional $500 i can have the roof, boot, a-pillar, spoiler and grill painted.
Interior:
Fire extinguisher mounted on transmission tunnel, below rear seat
Pioneer head-unit
Kenwood 6" front speakers
Pioneer 6"x9" rear speakers
Pioneer amp
Otherwise standard
The interior is in pretty good condition. There is the usual rip in the drivers seat bolster, minor fading of the door trims, slight scratching of the centre console, and a hole in the drivers side carpet.
I don't really want to sell my car... I've been devoting quite a bit of time and money to it in the last 12 months, trying to get it to just the way i want. Unfortunately though, as I'm going to go back to full time study this year, I don't think i can afford to hang onto it. My build thread (link below) should give you some good info on the car. I don't think it would need much for a roadworthy. It passed a RWC less than a year ago. If you have any questions, or would like to check it out, please don't hesitate to contact me.
Edited by jimtron4000
Build thread: http://www.rexnet.co...ain-green-my98/
Don't be deterred by the "issues" I've listed. I'm just being honest about the car, and these issues are really not that bad. Most 15 year old cars are no longer perfect... better to know the issues before you buy rather than after. The car has been very reliable. I was planning to use it as a track car and i believe it would be up for the job.
I could also possibly wipe $1500 off the price if you'd be happy with the standard TMIC, ECU, boost controller, injectors, and AFM.
Also I can chuck in a second set of rims (same type) with unused re540s semi slicks (225/45r16) for an additional $1000.
"The gearbox seems to be in good condition, with no real grinds or anything. It sometimes feels like it could engage 2nd more easily, but this could be due to worn shifter bushes. The shifter is very sloppy and it's bushes are most likely worn. There appears to be a bit of a leak from the centre diff. I'm very conscious of the gearbox when i'm driving, with no hard shifts or launches."
I've been under the car today, and noticed that the oil leak appears to be coming from the very rear of the transmission, and is most likely due to a worn output shaft seal. From what i've been told, this would not be a huge job to replace.
To eliminate the shifter slop, TIC offers a linkage update for $80 (http://www.entra.com.au/tic-5mt-linkage-update/)
"I broke part of the right hand side handbrake assembly when upgrading the brakes, so had to remove it from the hub. My handbrake therefore does not work at the moment. It hasn't bothered me so far, but i did plan to either fix the assembly, find a spare one, or install a hydraulic handbrake. The Intima SR pads are pretty new and are suitable for temps up to 700C (ie. track)."
I haven't contacted any wreckers about a handbrake assembly yet, but i just saw an STI (wont fit) one on ebay for $70. It should be pretty easy to find this part from most wreckers as it's the sameas that of any subaru with an r160 diff (ie. most).
I've been in contact with a painter who has quoted me $300 to fix the blistered clear coat, with a little more to paint the spoiler and grille (all up less than $500).
I will accept $9000 with the following items removed:
Process West TMIC
V4 STI 90mm AFM
Intima SR rear pads
... standard items will be fitted instead. The car won't be making 217kw like this, but should be making good power over stock due to the VF22, exhaust, and intake. The braking capability should be still quite good with the upgraded 4 pots up the front. In my opinion you'll still be left with a quick, great handling and stopping street car that could handle the track too.
OR
$10500 as it is in the original post.
I will also consider straight swaps with the parts removed.
    • Jamie does know his stuff , you might just want to give them a call and ask - here is their FB page  -  https://www.facebook.com/profile.php/?id=100063506985512 - you will find the number to call them on.
    • Do you think the guys in Penrith are install the E85 Kit?
    • Thanks Pac!   I will reach out to them!
    • Yes, but 2 things of the top of my head, 1. Legalities of nitrous on a street car. 2. No chop chop. I fully understand that there's much cheaper ways to make power, and whilst a wet 50 shot is fairly cheap to install, bottle fills are expensive, and bottles always need to be refilled, and nitrous also has its own inherent issues with reliability, and tuning, from my experience of others using nitrous, it doesn't take alot to lunch a engine real quick if something goes slightly wrong when spraying, if I wanted a big chunk of additional powers, a spooly boy would make alot more sense, disregarding the additional engineering, supporting mods and other logistical issues of sticking a spooly boy on a car that came naturally aspirated from factory  In the end I'm not racing for sheep stations, and I don't really care if people make more power, or are faster than me, or spend less, or more than me, the only thing the car needs to do is drive around and make me smile, which it is doing now Really, I just want a shiny new intake to look at when I'm cleaning the engine bay, and of course, some more induction doorts, and maybe even that 5kw for that elusive 200hp cherry on top that I might get If the FAB9 intake plenum, TB and air filter box thing doesn't eventuate for whatever reason, Plasmaman do one, not as fancy looking, and a fair chunk of more cash is required when including the TB and other bits and pieces that are required to install it, but, it is another option that is available to me if FAB9 one does fall down (but I really, really.....really, want the FAB9 one though) TL;DR. You want what you want
