Hi guys
looking to upgrade my car security system whilst removing the big bulky alarm system i have sitting in my engine bay.
As of now the car is having its engine ripped out so i need a mobile service.
Can anyone recommend a company around the South West side of sydney that will do a good job while not ripping me off?
http://www.securityinmotion.com.au/ these guys looked alright but honestly i have no idea
cheers
Have used Leon from security in motion several times, and can't recommend him enough. The guy does awesome work.
Can't remember which car it was for, but I once had to kick him out of the garage cause he was picking up every little bit of rubber he had stripped off the wires off of the dirty concrete floor.
All the work he has done for me has been faultless both in the way he installs and operation. Last used him a few years ago, but can't imagine him changing.
Just rang him up and he was very helpful
though we arent going to install anything untill the car is up and running again..
apparently he gets alot of warrenty work where the car has been pulled apart and they try to blame him for it not starting
So obviously gets his time wasted
A top level system is only as good as the person who installs them! I had James from Autowatch install a 5 point system (2 systems linked: Remote alarm + keypad immobiliser = 5 point interrupt!) in my old R32. That system was from Brant Corporation (link at bottom of page). Seriously, don't muck around with 2 point immobilised systems, Make it as hard as you can for a lowlife how doesn't give a flying f*%k about anyone but themselves!
http://www.brant.com.au/
    • Google says for a 1998 Nissan Maxima to pull/pry, and the metal pin might even come out with it. I'd do a bit more googling, there was a few videos, find some where the shafts/needles appear most similar and compare the techniques.
    • Details: Turbo Borg Warner EFR 9180 with 1.05 rear housing Upgraded TurboSmart integrated BOV Sanded and powdercoated compressor cover in gloss black Elbow welded with wiggins clamp Speed Sensor(Not included) (Can include oil drain(heat wrapped + titanium intake pipe with almost new filter for a tad extra). Manifold: 6 Boost RB26/30 twin scroll manifold  e-MAP ports drilled into both scrolls(I was using the TAARKS EMAP KIT) Turbo is in excellent condition. Always used Penrite 15w50 Racing oil(Changed less then 2000ks). Also using the Turbosmart OP regulator and filter. Downpipe: 4inch Stainless steel with VBand inlet and outlet clamps(included) Heat wrapped Dual ports for Dyno/Wideband usage Will throw in free 2.5 inch intercooler pipe(2.5inch From turbo outlet to 3.5 inch intercooler) - Powder coated black. Turbo made 563rwkw on mainline hub dyno at around 24-25psi boost - Pump fuel. Will def make over 600kw on e85. Didn't bother as my e-MAP was through the roof with my setup sitting past the choke line. I have a cnc ported and fully built head on my 3.2. Turbine speed saw max of around 109k rpm. I'm running this on my R32 GTR, with AC, and the original power steering pump. The manifold clears the AC lines, ABS, and everything else. Although I had new AC lines because I just wanted new ones and I heat wrapped them as well. This will make more power on a slightly lower capacity motor with a higher PR. And I have since upgraded to a G45-1500. Have pics and videos if need be.  Absolutely nothing wrong with setup. Turbo is in perfect condition. No shaft play or oil leaks at all. All the work was professionally done. The transient response of this is fkn amazing. I cannot rave more about this turbo. If I wasn't chasing 4 figures, I would have kept it. $5000 NZ. Located: Auckland, New Zealand.
    • I particularly like the look of the John Player Special team. (Thumbnail isn't different but hit play for the clip)
    • Such a cool collection of cars back then.
    • Mystery solved, thanks bro Bit of a strange mix, but i dont mind it, still looks good.
