Didn't ignore advice I've taken it in
Fo realz?
What size or ^cc injectors would be good for a 450Kw-550kw max build ???
if people are using 1000cc injectors for 300-ish kW, i'd say 2000?
1000s should do it. 1500 very safe.
1000cc ev14's are the go, or 2000's when you realise you can't make that power safely with 98.
Might go for 800cc sard
Just ignoring the childish comments bit pathetic
Just thought 1000cc+ injectors would of been more than enough Ive always had them on the cards was just seeing what other GTR drivers would suggest !!!!!
Seeing my suicide analogy went down so well with you, how about another...
Let's pretend for a second that you want to kill yourself. If you're a 10 year old kid averaging 40-50kg, you'll need to consume at least 60-70mg of cyanide to induce a histotoxic hypoxia leading to cardiac arrest (FYI this kicks in quicker on an empty stomach; stomach acid is your friend). You've read the threads, you've seen the 10 year old kids pulling this off and bragging about it. But they're lightweights - you're much older, you weigh like 85kg - you can handle your cyanide! So for some reason...and against the advice of those who care about you...you decide a 70kg 15 year old's dose of 105mg might be appropriate for your application. But oh noes...you're still alive. What went wrong? You didn't listen. You're still stuck here asking stupid questions on forums. You know what? Just go with the noose / buy a Toyota Echo, things are less complicated that way.
http://www.nitrostreet.com/injectors.htm
Engine Horse Power = 600HP (Your low range figure was 450kw)
BSFC = 0.65 for Turbo Engines
Number of Cylinders = 6
Injector Duty Cycle = 0.8
= 853.13cc/min
Now that is using 98 octane. If you were to go with E85 which will help you achieve your goals, you'll need approximately 40% more flow in the injectors (as well as a better fuel pump setup to keep up)
Additionally, this is for ENGINE HP, not WHEEL HP which I assume you're after when you said your goal figures.
Thank you god for putting f**kheads like this wanker ^ in the world
Good form
Your a hero behind a keyboard
And you're (note the apostrophe) a kid behind a leaning out engine...I know which I'd rather be. No need to hate, I chose the right injectors for my application.
This made me laugh! Love it!
    • I thought about ditching it but I was worried my bonnet would sound like a 90's Swift GTi sub-filled boot.
    • Have you found that you have to tighten your alternator belt once in a while? Mine has started to squeal again after the mechanic tightened it roughly a year ago and the engine starts up slow if I don't start it every day (think the starter motor is going out). It used to be if I don't drive it once a week I'd get a quick squeal on the belt but now it's every day or every other day. I might make a post of the start up sound.
    • I spent the entire of the long weekend going through my garage and I'm now, after 3.5yrs in this house, able to fit a car in. The garage is quite long and the back half has a high enough ceiling for a 2 post lift but it's going to just take too much space and I don't think I'd be able to get around the car if it was in the air. So, in comes the quick lift. It looks perfect. High enough to do most things, I reckon even getting a gearbox out would be doable.  Does anybody here have one? They're fairly cheap (~$3k) considering...  https://www.dtmtrading.com.au/product/quick-lift-portable-vehicle-hoist-3500-kg-worksafe-approved/ I'm also a bit of a non risk taker so I'd probably still use stands when under!
    • Well now we all see it! I did the same. Then cut it out. Then melted half of it. Then discarded it entirely. So... you're in good company.
    • I just replaced the god awful, sagging, crunchy bonnet insulation. It's something nobody but I see but it's been at me for a while.
