Didn't ignore advice I've taken it in
Fo realz?
What size or ^cc injectors would be good for a 450Kw-550kw max build ???
if people are using 1000cc injectors for 300-ish kW, i'd say 2000?
1000s should do it. 1500 very safe.
1000cc ev14's are the go, or 2000's when you realise you can't make that power safely with 98.
Might go for 800cc sard
Just ignoring the childish comments bit pathetic
Just thought 1000cc+ injectors would of been more than enough Ive always had them on the cards was just seeing what other GTR drivers would suggest !!!!!
Seeing my suicide analogy went down so well with you, how about another...
Let's pretend for a second that you want to kill yourself. If you're a 10 year old kid averaging 40-50kg, you'll need to consume at least 60-70mg of cyanide to induce a histotoxic hypoxia leading to cardiac arrest (FYI this kicks in quicker on an empty stomach; stomach acid is your friend). You've read the threads, you've seen the 10 year old kids pulling this off and bragging about it. But they're lightweights - you're much older, you weigh like 85kg - you can handle your cyanide! So for some reason...and against the advice of those who care about you...you decide a 70kg 15 year old's dose of 105mg might be appropriate for your application. But oh noes...you're still alive. What went wrong? You didn't listen. You're still stuck here asking stupid questions on forums. You know what? Just go with the noose / buy a Toyota Echo, things are less complicated that way.
http://www.nitrostreet.com/injectors.htm
Engine Horse Power = 600HP (Your low range figure was 450kw)
BSFC = 0.65 for Turbo Engines
Number of Cylinders = 6
Injector Duty Cycle = 0.8
= 853.13cc/min
Now that is using 98 octane. If you were to go with E85 which will help you achieve your goals, you'll need approximately 40% more flow in the injectors (as well as a better fuel pump setup to keep up)
Additionally, this is for ENGINE HP, not WHEEL HP which I assume you're after when you said your goal figures.
Thank you god for putting f**kheads like this wanker ^ in the world
Good form
Your a hero behind a keyboard
And you're (note the apostrophe) a kid behind a leaning out engine...I know which I'd rather be. No need to hate, I chose the right injectors for my application.
This made me laugh! Love it!
    • One of the things that never seemed right was the handbrake. Put in some nice new Project Mu shoes. We figured the rears were out, so why not. We're right there. My handbrake never worked well anyway. Well, this is them, 15km later. 67fdcf94-9763-4522-97a4-8f04b2ad0826.mp4 Keen eyes would note the difference in this picture too:   And this picture: Also, this was my Tailshaft bolts: 4ad3c7dd-51d0-4577-8e72-ba8bc82f6e87.mp4 It turns out my suspicions that ne side of the handbrake cable was stretched all along were pretty accurate, as was my intuition that I didn't want to drop the tailshaft to swap them on jack stands and wasn't entirely sure about bolt torque. I have since bought the handbrake cables which have gone in. I'm very glad that I went to my mechanic friend who owns an alignment machine to get an alignment before the track day, because his eyes spotted these various levels of "WHAT THE f**k IS GOING ON HERE?". Turns out the alignment wasn't that bad, considering we changed the adjustable castor arms out for un-adjustable castor arms, and messed with the heights. Car drove pretty good with one side of the handbrake stuck on, unbleedable rear brakes, alignment screwy, and the tailshaft about to go flying and generally being a death trap waiting to happen! (I did have covid) (I maintain I adjusted the handbrake correctly, but movement caused shennanigans and/or I dislodged the spring on the problem side somewhat, or god knows what). G R E G G E D
    • Very interesting, im not sure how all those complications fit in to running a haltech instead of a stock ecu but I'm starting to think I'm a bit out of my league.
    • I just put 2 and 2 together. This is a Neo converted R32. The Neo ECU (in concert with the R34's AC controller) runs the AC quite differently to how the R32 ECU and AC controller do it. If you just drop it all in, it won't work. There is some tricky wiring required, including changing to the pressure switch that the Neo controllers want to see. I don't know what it is, because mine was done by a guru. It was a year or so after I did that transplant before he worked out what needed to be done.
    • Don't assume the AC relay signal from the ECU is +, some models including Stagea use an earth trigger.
    • Hey good to see you on the forums! Haha Considering this cars past with electronic issues I am leaning towards it being a wiring fault somewhere in the engine bay. When testing the ac relay in the fuse box there was no earth trigger. I am probably going to try "bench test" the compressor by giving it direct ground and power to see if i can hear the ac clutch click otherwise I will be pretty sure I have a dead compressor. If it does work then I will be tracing some wiring it seems.
