  • Replies 160
I'm in =)
Thats what he said to you Benji? lol
Good turnout to this one by the looks of it, i better do some work on the nugget then!
I'm in. From Sydney.
MOAR YELLOW R34!
You are becoming a regular :P Be good to see you again man! Can show you some new mods haha
And YES MOAR yellow is always good!
It's been too long! Be keen to check you car out.
I should modify my car before I come up. I've neglected it for a long while, Hasn't seen any new mods since I was in Goulburn.
Might just chuck a new BOV on it and tell myself I'm a legend.
Lol mine has undergone a fair bit of surgery since Goulburn :O Stupid thing! Ill show it fuel issues!!!!
Yep BOV and some neons! Actually chuck a set of space savers on too haha
Keen to see it dude.
My car is going to look so sick with some neons. But I probably will put an BOV on, I like my car to be obnoxious in every respect.
Car has to match the driver.
I feel sorry for its socks then :unsure:
I dropped in and saw Norm tonight and he is certainly keen to bring the GTR out....
NORM!!
There's a hillclimb the day before this cruise, there's a thread for it somewhere. I think it's around Raymon Terrace.
You should get in on this too, Matt and myself are entering then staying in Newy/coast for the night then the cruise the next day. So we should slay a million schooners that night.
NORM!!
Its like 10 mins from my house haha!!
Depends where you stay man, if you are close by i think schooners are in order.... And YES i am going to try get to that hillclimb thingo :)
Well if there's some accom around your place then we'll chuck an overnighter there. Hillclimb + schooners + cruise.
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
