Well that means you are only about 500m from my house and about 1km from the pub, and 200m from maccas lol
I'm going to need all of these things in the span of 12 hours or less.
God help me.
  • Replies 160
God help me.
Hahahahaha oh shit! Should i warn the local police etc? (Oh your place is also about 1km from the biggest police station known to mankind)
They'll have a bed made up for me by the end of the day.
End of the day? :blink: They will have road blocks on the way in haha
REMEMBER GUYS, Save the phone numbers as SAU will be shut down soon!
Nice speed limiter pal, do they make them for men? :P
What colour did he end up with? Havent checked FB..... Tell Sushi to come drunk or not!
Oh and guys, SAU will be down for maintainance... IF you are wanting to come and need any other info call one of us... You can get me on 0434353292 if you are stuck or late BUT Ant knows all the details and is organising the cruise so its probably best to contact him directly! I havent even looked at the details :P
Its like a smokey black colour, darker then gun metal not quite black.
where is the meet point for the sydney siders as i might be able to make it just need details
Ask Luke as he was making the trip up, he may need an hour head start tho :P
What about a cafe? I can't get going in the morning without my decaf soy latte...
How about a McCafe? Because if you dont like that then you are McFkd :P
So what is the actual plan for Saturday Night?
When is everyone heading to the pub? And can I leave my S15 at your work Matt?
NO! I dont want no 2 cocks from the sphincter of the universe Toe in my shed! :P
After hill climb its pub, there are no plans apart from whatever happens at the time
jeez, what have I gotten myself in to...
You ever been shot before? Or will it be your first time? If so, you are in for a treat haha :P
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
