FOR SALE:
GENUINE garrett gt3582r (also known as gt35r & gt35/40) dual ball bearing turbo. It has a .70 front housing, and a 1.06 rear housing which has been ceramic coated inside and out. This turbo is rated to 700hp. It is basically brand new, as it has never been fitted to an engine, or seen oil or water. It has been sitting in my cupboard for my project r33 . Very regretable sale. The turbo is advertised elsewhere, so it won't last long. I reserve the right to end the auction early if the turbo sells elsewhere. I am located on the Mid North Coast NSW and I can be contacted on 0401992230. Cheers Thomas.
$1200
https://www.sau.com.au/forums/topic/418332-garrett-gt3582r-turbo-new-unused/
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
