Recently replaced the head gasket, head was skimmed, new factory gasket with hylomar (CA18DET).
After driving the car and getting it hot I found it was "gurgling/making a boiling noise from the back of the head more on the intake side.
I jacked the car up and let it run for twenty mins or so and kept squeezing hoses as I assumed it may have air in the lines. It pushed air into the overflow for a while then stopped doing it.
Last night I drove it again after a good warm up and when I came back it wasn't gurgling straight up but started to when I cracked the radiator cap (which also released some fluid into the rag I had there).
It had stopped before I grabbed my camera, but I did record the sound of fluid swishing around coming from the same place each time I squeezed the top radiator hose.
I'm inclined to think the radiator level has dropped, but how much of that was fluid out the cap is unknown.
When I was trying to get the air out, I had the heater on full pelt also and gave the car plenty of revs as well.
My main concern is the headgasket is not sealing. Is the easiest way to check to get a pressure test done? There does not appear to be any oil in the coolant, as there was last time, but the gurgling makes me think that when I shut the car off it's sucking air in somewhere from a leak in the cooling system.
https://www.sau.com.au/forums/topic/418368-gurgleboilfluid-noises-video/
  • Replies 68
My first guess would be the coolant boiling when you stop due to having no air flow through the radiator.
Did you replace the old fluid with proper anti boil coolant? Proper coolant as opposed to just corrosion inhibitor raises the boiling point of the coolant to prevent it boiling if the cooling system can't keep the temp under 100 degrees c.
It might pay to bleed the coolant from a higher point. Put a funnel or something that will seal in the radiator neck so that you can have the level higher than the radiator. Then open the bleed screw (I presume CA's have them, most Nissans do) and bleed out any additional air. Tighten up the screw while the level is still higher in the funnel than the bleed screw.
If you've got good coolant and it's bled properly then you need to check your radiator to make sure not too many bent fins and not blocked with bugs and crap. Is the radiator old? It may be blocked. Check the thermostat to make sure it's operating correctly (remove it and put it in boiling water to make sure it opens at the right temp (have thermometer in the water).
If everything else looks ok then you might need to have a look at your water pump to make sure the fins aren't corroded. That's a longshot though.
That should give you a few things to try anyway.
Good luck!
- Coolant is a mix of the old coolant, that was slightly oil contaminated from the headgasket, and fresh water that was put in the radiator to get the car going. I have some radiator cleaner and plans to flush/clean, haven't done it yet while I'm wanting to work out if it's sealed properly.
- CAs dont have a bleed screw, which is why I jacked the car right up so the radiator was the highest point and ran it for twenty mins or so squeezing pipes as I went, air did come out but who knows if it was all of it.
- Radiator is pretty new/in decent condition.
- Thermostat is only 2000ks old and is a high flow unit, it's working properly as the coolant flows as it should when warm.
- The noises come from the back of the engine and I'm semi thinking that the coolant level dropped by some of that came out the cap when I removed it.
- I have an aftermarket gauge and it doesn't go above 77 or so degrees.
I will make some calls at lunch and see what a pressure test costs, I really need to be sure it's sealed.
Edited by ActionDan
Ok, that covers most of it then. I would definately flush out the whole system and put in proper coolant before going too much further.
What is the highest point on the engine that carries coolant that you can remove to allow the air out? Using my method from my first post, rasie the fill height of the coolant and remove the hose or whatever is highest to allow any further air to get out.
It would probably be the top hose which connects to the thermostat housing, that or the radiator cap.
As I mentioned though, I went through that process and my main concern is the drop in coolant level implying it's leaking out or into the engine.
Haha, not panicked, it's just a track car so it can sit for however long to get fixed. Just don't want to hit the dyno and dial in the new parts if the gasket is not right.
Natrad guy, who was very friendly and helpful, told me pressure test will not help and suggested I'd be better off fully flushing the car then TK testing it, I have access to a TK tester.
I'll keep running/driving the car also, if the level keeps dropping then it's going somewhere, if it's just air escaping then it should level out at some point,.
Edited by ActionDan
I did some more work on it last night with a radiator tester a mate had.
Fouund 3 leaks at 100psi test pressure.
- Top radiator hose which required 2 hoses clamps before I could not hear the air escaping any more.
- Water temp sender adapter which I was able to seal up with a new/better hose clamp.
- 2 lines under the intake manifold next to each other that I'd not tightened up properly.
I made sure they didn't leak up to 140psi on the gauge then let it idle jacked right up for 10 mins before taking it for a belt.
When I got back, the car still gurgled at me, but I got it on video this time. There's a noise halfway through the clip, that's the missus banging around outside the garage water plants.
Forgot to add, it didn't make any noises in or around that area while I was pressure testing it.
Maybe I should pull the spark plug on 3 and 4 (where the HG was blown last time) and see if I can see/hear anything at the same time.
I'll try and line up a TK tester, but I have to fully flush the cooling system first as this older coolant would still have some oil in it from when the HG went.
The boiling point of water + whatever additive you have in there will change with pressure. The lower the pressure the lower the boiling point. I would fully expect it to make that sound if you crack the rad cap as you have released the pressure from the system. (Remember in science class making water boil at room temperature in a vacuum?)
If the system is not holding pressure it will boil like this. The system will be fine while you are driving and the water temp is low. In fact, you you are just driving along at highway speeds on a coolish day it doesn't even matter if the rad cap falls off. But on a hot day, or when you stop the car and the heat from the block soaks into the water, it relies on pressure to stop it from boiling.
Just my 2c
Jeff
Edited by datsun_1600
Agreed Jeff, but look at the most recent update.
Drove it last night after fixing some leaks and it gurgled without the rad cap being removed.
There definitely could be more leaks, so I will do some more testing.
The big ticket for me was that I could not hear anything in/around the head area or where it was been gurgling. I will flush it all out and get a TK tester on to it, I can deal with it getting some air in or leaking a tiny bit somewhere but I don;t want to put it on the dyno if the head gasket is not sealing.
Is the cooling fan operating correctly? If it's not engaging properly when you stop it won't suck air through the radiator properly to replace the action of the airflow from driving.
The gurgling sound won't be the actual leak, it's the coolant boiling in the block. It may be because there is a leak and as Jeff says, pressure as well as the coolant raises the boiling point of the fluid. But you say you tested up to 100psi so pressure shouldn't be the problem. That's WAY above what a normal system would operate at (from my recollection anyway!).
Clutch fan seems to be working fine, car doesn't get hot on the factory or after market gauge. It's certainly spinning as expected and I have the shroud in place.
Just get that noise and I thought it may have been using coolant but as I fixed 3 different leaks it's entirely possible that was why.
100psi on the gauge has test next to it, I went 140 after fixing leaks and could hear/see nothing else leaking.
If I let the car idle long enough with the cap removed the coolant level rises to a point where it would start over flowing if I left the cap off which is why I don;'t want to follow a suggestion I was given of driving it with the cap off.
I've jacked it way up twice and let it idle for 15-20mins each time, my jack goes 498mm. I'll get under it and triple check the coolant hoses up under the manifold.
This weekend I should be able to drain everything, flush out the old coolant and put fresh stuff in so I can TK test it without the old stuff in there.
Ah yes - sorry I got busy and wanted to reply. Should have read right through. 140psi ? Wow, I would have thought that would blow the core / welsh plugs out of the block! My very very very modified Datsun L20B engine used to do this, the only way I could stop it was to let it idle for a bit to cool off before shutting it down, and also run fans etc after it was shut off.
I'm currently rebuilding the engine - it now runs an electric pre / post oil pump, electric water pump and fan after it's shut off.
Jeff
I'll re-check the tester then maybe it;s not psi and in fact something else. It's definitely 100 somethings.
At 100 (whatever the unit is if its not psi) the radiator hoses are almost rock hard to touch, they were not anywhere near that hard after driving it and keeping the cap on while it was hot and pressurised.
Interesting.... Wonder why it's not building pressure in the system when you drive it.....
    • Keen to see the turbosmart data, to date I've only seen negative things in terms of response for them. Very small sample size though.     Hawkins is a big advocate in his videos of the larger rear housings. I managed to make similar power with a lower spec motor on the smaller .8 rear, keeping decentish spool.  The people he works with now are big power cars compared to mine though, mine really is setup to drive around and enjoy.  I don't have any back pressure monitoring though, so couldn't say if its good or bad on my car, just that it does what I want it to do.   Future I want a higher compression more cubes motor to give a bit more bottom end and hopefully the new g35-1150 gets me to the 850 rear comfortably.  But maybe I won't due to exhaust back pressure.
    • No, I refuse to buy their cheap ass crap! I do need to order a bunch of different nuts/bolts to refill my nut/bolt wall though. Maybe you could go for a walk through Bunnings for me? (Or send me some stuff from your work? )   I really struggle to work out how the US standardised to Metric in what the 70s or 80s, and yet, half a century later, there's been little done to actually bring it into fruition. It truly baffles me    On the whole Fastenal thing, I went reading their site (My god they sell a lot of varied stuff!), and it seems like it really depends what store you're near if you can walk in and just grab a few small things, or if that branch is primarily distribution with only a small window of "counter time" available (if at all). That definitely makes it harder, as move locations and it drastically changes your ability for success   For things like your M6x1.0, if you want to work on your own Skyline, and you also have a "home workshop" I'd recommend setting yourself up a small Nut/Bolt wall/section. It doesn't even need to be big at all. Most things depending on the diameter, will be a specific pitch, like the M6x1, M5x0.7 etc. Bigger bolts is mostly 1.5, except for a small number of things and that will come down to torque. From memory bolts for the brake calipers (and other things that need a lot of torque) will end up being a 1.25mm pitch. Save up a few dollars, and order a range of nuts/bolts. If you want to minimise cost a little, buy something like M6 x 40, and M6x70mm (1mm pitch) in both. In addition, buy yourself an M6x1mm thread chaser. That way you have long bolts that you can cut down to size, and then chase the threads out. Funnily enough, I find what I'd pay here for ordering 5 bolts, I can pay about 50% more and you'll get 100 of them.   If that doesn't quite work out due to space / ability to buy plenty up front, then each time you need some bolts, order 100 of what ever you're getting. Put them in clearly marked containers. Over a few years, you'll acquire plenty of different sizes, and will end up ordering less and less. And the cost for 100 bolts won't be much more than you paid for your 5 you needed to order anyway  Just takes a little planning ahead, by investigating what nuts/bolts you'll need, and ordering them before doing the job.     Edit: If it's also primarily for working on just the Skyline, for some reason my brain is screaming that at some point, either Nissan, Nismo, (Or possibly a third party) was selling a "kit" of every nut and bolt in a Skyline, purely for people restoring/rebuilding. It'd likely be quite expensive, but would give you every/any nut/bolt you need for stock/factory things. I'm not sure if it's still available, or even if it actually fully came to market, it's just something niggling in the back of my brain that you could look into further if that sort of thing interested you? (It might have been for the R32 GTR or something specifically too, and not just any Skyline)
    • 90lb/min @ 20psi is wonderful, not so much of a problem with the G35-1050's compressor efficiency (aside from how bad they roll back at higher pressure ratios).  The issue is more to do with the turbine's flow, which is why I'm not sold on going an even higher flowing compressor with the same turbine.  I'd say go back over Motive DVD's testing of the G35 1050 and Hawkins's comments regarding exhaust back pressure issues with it, I'd need to go back but I have in my head he went to the biggest hotside and ended up sacrificing a lot of spool (so it ended up behaving like a bigger turbo) and still had EMAP issues.  I've heard various other experiences along the lines of that. At this stage at least I rate all I've seen about Xonas (for transparency I've not used one directly, but I have spoke plenty with people who have) to have low exhaust restriction for the response they offer for any given setup - basically they allow the engine to breathe, which is good for the engine and makes making power a lot easier.  You arguably don't have to even push quite the same amount of airflow through an engine to make the same power if you don't have the bum plugged up with exhaust gas struggling to escape the engine due to an underflowing turbine.   In terms of reliability, to be fair I've had great luck with Garrett turbos as well - my GT3076R lasted forever, then I sold it and the next owner had no issues, then that car got sold and it was still going strong last I ever heard about it.  The trick is with the old GT-series turbos the compressors etc were no way near as efficient as what we have these days, it was almost hard to push them into severe overspeed situations without having a boost leak or something - and that is what often starts the failure situation.    In terms of your G35 I'm pretty sure you're running yours within sensible limits, something people with Xonas and Precision turbos aren't often so inclined to do.  The "compressor maps" are "Joe blogs ran 45psi through his 6466 so I can do the same" and built their setup to send it to the moon.  I've seen EMAP and compressor speed data where people have actually set that stuff up on Precisions and Xonas which have been run hard and the comp speed numbers are very very exciting at times - like I've seen 76mm Precisions run at rpm that you ideally shouldn't run a G35 1050 lol.   I know people who have run G-series Garretts hard and hard a failure, then replaced them with Pulsar turbos as a cheap "get it going" stop gap with the intent of doing a proper upgrade when THAT fails... and are still running the same thing.   Like anything, ymmv and it's not always to do with the quality or trustworthiness of said product. I've been provided with a bunch of compressor maps for Turbosmart turbos and will update my list based off that, they could prove to interesting reading and an interesting alternative as well.
    • Just cage it, call it a race car, and then fall in love with the chirp chirps through pit area!   Also, this is coming from someone with a completely locked diff...
    • I still have an old R32R left over from when they were a thing in the early 2000's. It was, for its time, done about right. But its time was 20 years ago.  I did try and update it a while back but it was cruelled by a (recommended) muppet of a tuna who couldnt tell his MAP from his TPS. The original spec was: Power FC, 700cc Sards, Nismo pump, 2860-5's, cams (Basically Poncam A's), Z32 AFM's and a half sorted oiling system. Thereabouts 430rwhp irrespective of what was done. So, yeah, very 1990's. I eventually got sick of it not being very refined and bought a Link G4 PNP with some 1000cc Bosch injectors. This was tuned badly and I put the car in the shed for a few years whilst I sulked and went and did other things. Ive come around to the idea of getting it going again so it has a new gearbox installed and some other minor things in the planning. So my questions are, variously (In the context of keeping the Link) What other sensors should I be running eg It has no wideband on it at the moment, nor fuel pressure. $? Is it worth chucking the old ignition system (ignitors etc) for new ignition coils? $2k? Cam/crank angle sensors? Can keep the aircon? $? Anything else? Sorry to launch another what should I do with my car thread but, you know, what should I do with my car? Random photo for historical context.
