Hey people
I have a manual R33 non-facelift RB20E Coupe that I have used as my daily driver for the last few years - even in this underpowered forum its still a bunch of fun to thrash and its not too hard on the gas either, at least compared to my weekend car which is a Rev D E-Tune Legacy which opens a little valve under the gas tank when I drop my foot.
To make it a little more exciting on the way to work etc with the R33 coupes big bum I wanted to increase the power without going turbo, preferably by adding some torque into the equation.
So my question - is there anything major I need to do to drop an RB30E in? Or can I literally swap the two without modifying anything. And the second question is, how much of a mission is it to drop a 25DE head on an RB30 - will I run into ECU issues and need different headers etc?
Failing that I could look at putting a standard RB25DE in there - but from what I understand I may need to change the ECU etc anyway so I may as well go RB30DE
Cheers, and please excuse the 'sign up and ask a question' first thread : D
Edited by Greaver
https://www.sau.com.au/forums/topic/418383-non-turbo-rb30-into-rb20-r33/
Hey people
legalitys aside an r32 rb25de head onto a rb30 bottom end is pretty easy, been done a heap of times, use a nistuned rb ecu to run it
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
