IDa will be holding a drift event at Eastern Creek on Saturday, 5th of June, 2004. The event will be held on the Eastern Creek Skid Circuit, a concrete low friction surface.
We will be running 2 sessions. The first in the morning will run from 9am to 1pm on a wet track. This is a perfect opportunity for those wanting to "give it a go" to get out there. The second session, run from 1pm-5pm will be on a dry circuit.
You may register for either one or both of the sessions.
Should you only wish to participate in one session (either wet or dry) the cost will be $60 to members and $75 to non members.
Full Day (Both Sessions) $100 to members and $130 to non members
Special Requirements
As a member of CAMS, Initial Drift will be requiring that all drivers and passengers wear long sleeve shirts and pants covering ankles to wrists to neck. Appropriate footwear must be worn along with a CAMS approved helmet (any AS helmet will do).
These requirements are not open for interpretation and are ultimately for your safety (http://www.initialdrift.com.au/forums/view...php?p=6608#6608). Please ensure that you bring the necisarry gear as you WILL NOT be running without it.
CAMS Licensing
For insurance reasons all drivers must hold a current CAMS license. Should you not have a current or valid CAMS license, that is OK. Initial Drift will be issueing daily licenses for $20. Passenger will also need to hold a CAMS license.
Register your attendance here: http://www.skylinesaustralia.com/forums/ca...do=getinfo&e=57
boxheadmr, can I please get a link to the supp regs and entry form so that I can add it to the calendar entry
Thanks
Tosh
I am sorry to hear that B-Man - PM Sent for your views on the day
This is only a practise day, all the info that is required in regards to what you need for the day are above.
To Pre-Book your spot send me an email on [email protected]
Thankyou for putting it into the events section :)
Hi Matthew - I have sent you a PM - Thanks for the opportunity to give you some feedback - please take it as constructive.
Apologies for my in-appropriate response to your post above -
Good luck with the day.
    • Thanks for the update I truly appreciate it. I was trying to figure out the sensors.
    • My son recently purchased a 93 Skyline GTS25 (NA), I am hoping to get some insight as to what potential this car has.  I have auto mechanical experience, and I am capable of working on this vehicle, but I know nothing about it.  Where's the best site to purchase parts (maintenance, repair, upgrades)? What kind of upgrades are available?  Thanks again and I look forward to any information that you all have to offer!   Darrick
    • This is a pump I have used in the past; no oil ever leaks or gets past the regulator plug.I was trying to understand what caused Nissan to not only mention it in their manuals but to also state it's a replacement part yet the part cannot be found on my pump or on any new pumps and there doesn't seem to have ever been a replacement part#.  First time I've noticed something strange like this from NIssan.
    • yeah I have brown peeking out from in between some metal sheets close to the hood hinges. Strut towers look fine, even around the edges. some images https://imgur.com/a/brGt3Tu the one that looks the worst is the panel(s) going away right near the firewall on the passenger side, from underneath. Driver side does not look that bad.
