Would have to be 1k wouldn't it? I'm not really sure what mild steel prices are. Stainless would have to be what 1.2-1.4k for a decent cat back 4"? I really have no idea but just a estimate.
  • Replies 73
$700-800.
Be nice do have a custom centre and rear muffler made that actually work, so we can run these big systems and not worrie as much about the cops.
My tomei system, flows awesome but it's stupid loud.
If I was to do a minimum of 5 systems using 4 inch mild steel with resonators and mufflers I could do them for $1200 each with flanges, bolts and gaskets.
4 inch mufflers and resonators aren't cheap
By comparison a 3.5in system doing 5 of them I'd say $880-990.
Does anyone have any actual knowledge of what effect (if any) it would have on an engine to have the cats staggered on a twin system? By that I mean having one cat slightly closer to the engine than on the other pipe to allow them to fit under the car better?
Like this picture (best photo I could find!)-
I tried Googling but couldn't really find any info.
Any effect if any would probably be negligible.
It wouldn't hurt to stagger the cat’s so there equal distance from the turbo’s – that would ensure all things are indeed equal.
Edited by R31Nismoid
I can't remember what underside I saw, but there are some cars in the US doing it (modified). Can't see it as a problem as if you put them side by size "technically" they aren't event anyway given the front turbo is further away, and such setups work without issue. So you are effectively making it better.
Just ensure there is a cross over pipe somewhere if doing separate CATs/pipes.
Good point, I stupidly didn't think of that! In theory that makes it perfect! The offset would be nearly identical.
I remember when I was a tech at Holden when the whole crossover pipe thing came along. Late 90's early 00's from memory. If it only makes it a bit quieter then it's worth it.
Not so much the sound level, it's more the fact that going 3 cylinders per pipe, without a X-over, sounds really bad in a lot of cases.
Last car i heard like that didn't sound like a "RB" at all really. It was weird.
pretty sure there are some jap twin exhaust that don't have a crossover pipe....can't recall how good or bad they sounded though.
Edit: just checked a few u-toob vids and they sound like crap. I have always wanted a twin 3"...but I think a single 4" will do.
Dual 3" exhausts is the same as having a single 4¼" exhaust.
Can you post some links Charlie? I must have shite searching skills as i couldn't find any!
  • 1 month later...
After reading this article http://www.modified.com/tech/modp-1102-exhaust-test-tech/
It seems like there could be a gain by going 3.5 inch. I already have the trust extension pipe which are 2x70mm. so to get perfect sizing, I should get myself a 4 inch cat-back to match the 2x70mm total exhaust diameter.
However, my setup is a RB26 with stroked 87mm piston and -5 with cams and all the supportive mods you could expect.. My cat-back is 3 inch right now. So, going 3.5 is quite easy, theres tons of aftermarket BUT theres very few 4 inch catback..
Whats your thought, anyone saw gain from 3.5 to 4 inch ? Should I really concentrate on having both the downpipe and catback ''flow-matched'' or simply stick in a 3.5 instead of my 3 inch and call it a day ?
P.S: I'm also keen about a 3.5 or 4 inch group buy in stainless steel!
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
