Non prepped road surface with some gravel, this time will be much better on a proper strip :yes: AND if Mani stays off the limiter :D
This is true haha
We plenty of wheel spin at the start due to rocks
But I also didn't launch hard at all so my 60ft would be shocking haha
250rwkw r33 (Full weight)
14.300 @ 122.6mph
14.909 @ 119.92mph
Does this sound about right?
Got these results from the SAU Nats Airport run
Speed trap was about 30m before the 800m - not the 400m.
The only thing that was measured @ 400m - was the time.
  • 2 months later...
  • 2 months later...
  • 1 month later...
  • 3 months later...
  • 4 weeks later...
No Point in starting a new thread so I might as well use this one.
I ran at Calder on Friday night and the best I could manage was consistent 12.6's on shitty tyres and old tien coilovers that are as hard as a rock. MPH averaged between 108 and 112.
My car has dyno'd at 325 rwkw and it's a full weight 32 GTR.
What are peoples opinions on the low MPH?
I'm considering stick it back on the dyno and maybe checking for some boost leaks?
    • Don't turn down the limit yet. Put a mechanical pressure gauge on the car in the same spot and go and prove it.
    • I've done a few BMS systems. Code in Canada use to force us to have any safety components outside of the PLC but with a code change back in 2018 I believe it was, we can now use safety PLC's to control everything. Sadly to your point, AB Guardlogix safety instructions for example are only available in ladder.  Machine safety is a very big thing here though, you're constantly forced to migrate to the next best thing by OSHA. I honestly prefer safety plc's, including anything from AB more then I do working with old school safety monitoring relays. PLC is only one portion of it, the rest of the electrical still has to follow to meet SIL (Mechanically linked dual contacts, bla bla)  Now tell me how to feel about safety over comm's (e.g Ethernet/IP CIP) on a unmaintained network haha
    • To your point, boolean logic. We're not only working with bools in ecu's, so it's very limiting. I wanted to setup a low WMI pressure alarm. After 1 second I want WMI line to hit 100PSI, 2 seconds 175PSI, etc. and trigger an alarm if it doesn't meet those thresholds. This would of taken me one very short line of text, but instead I had to bugger around with generic timers, conditions, etc. and so forth.
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
