  • Replies 50
2012 SAU-Vic EGM/Committee Elections
Time: 6:30-10:30PM (7:30PM Formalities)
Date: Wednesday 20th Feb
Food: Finger Food.
Drink: Beer & Soft Drink
The 2013 SAU Vic elections will be held via EGM at the February Club Meeting on Saturday 16th February 2013
At this meeting, the new Committee for 2013 will be elected. All current Committee members will step down on 16/02/2013.
So when exactly is / was this?
And isn't it the AGM (Annual General Meeting)? An EGM is an Extraordinary General Meeting.
An AGM is exactly that an Annual General Meeting
And EGM is an Extraordinary meeting, a meeting called upon by the Committee members
Not sure what the relevance of whether its an AGM/EGM has any bearing on the topic discussed at hand
"The Annual General meeting (AGM) is an important event for every organisation. It gives its members, the general public and the committee a broad overview of the organisation's current directions and financial health and confirms its purpose.
It is also the time to revitalise the organisation through the official engagement of members into key elected positions."
An Extraordinary General Meeting is called at times other than an AGM, usually in response to a crisis occurring in the running of the organisation.
Feb 20 is surely the AGM, as dictated by the rules of incorporation.
Are we really going to argue becuase the post has an E and not an A? Are you not going to turn up because its an EGM and not called an AGM?
The agenda of the meeting is clearly outlined in the first post.
The rules of the Club are governed by the Club constitution, this dictates how the club is run. There are no set rules from every incorporation. i could call it a PGM (Party General Meeting) and if that's what the constitution says that's what it will be.
In addition we have already had a AGM this year. So should we call this our Double Annual General Meeting?
If you have any further issues of what we call our meetings please contact Consumer Affairs on 1300 558 181.
Or feel free to nominate yourself as Treasurer and re-write our club constitution.
Sorry Tony, but you are wrong. The club may be governed by its constitution, but that constitution is governed by the Incorporations Act, which has recently been amended. As an executive committee member, this is something you need to be aware of. The Incorporations Act contains what are termed "model rules", and it is these that are generally used to form the constitution of incorporated bodies, like SAU-Vic.
If you have already had an AGM, then that is the time you should have elected a new committee.
Because the Incorporations Act 2012 has changed the "model rules", many incorporated bodies are calling Extraordinary General meetings to pass a resolution to the effect that their constitution be changed in line with the revised model rules.
As an executive member of the committee, I suggest you familiarise yourself with the rules that govern the operation of incorporated bodies.
The club's constitution doesn't need re-writing, it just needs to be adhered to. Unfortunately, I can't stand for committee, as I am not a financial member of SAU-Vic.
(FWIW, I have some 20 years experience in serving on the committees of various incorporated bodies)
It's governed by the 'model rules' or it can create its 'own' rules.
Model rules versus own rules
Your association may use the model rules, or create its own rules. Either way, the rules must address every item listed in Schedule 1 of the Associations Incorporation Reform Act 2012
If you want to further discuss this please take it to PM and not to clutter this thread.
    • Update 2: Today I'm f**king pissed. Some of you probably saw my thread that I opened shortly after joining this forum, "urgently need expert/experienced opinion", in which I discussed the possibility of a porous RB26 engine block which I also found hard to believe. Currently both turbos are out since the shitty braided line that was installed by whoever fitted the GT28 turbos leaked oil onto the exhaust. Today while working on the cam covers to put new gaskets and half moons in, I cleaned the side of the engine block with brake cleaner. Some time later I saw that it was still glistening with oil or coolant so I dried that off. But it was wet again shortly after. Verdict: I'm royally screwed. What you can see here (hopefully, despite shit resolution), circled in red, is a crack above the turbo oil feed. Extent is a few cm long and basically goes from #3 cylinder wall to #4 cylinder wall. It slowly lets coolant through, even without any pressure behind it. I am absolutely dumbfounded as to how this crack even formed, especially since it isn't along the cylinder as it usually is but rather a horizontal crack. Probably a few cm in length. Not sure on how to deal with this issue right now. Most likely, the only true fix is a new engine block, and even a relatively well done temporary fix requires at least a full engine teardown. Neither of those really fit my timetable right now, the car has been in my buddy's garage long enough as it is. I'm open to suggestions, but I'll be looking into ordering a new 05U block soon so I have one ready for the coming year, or whenever the current block inevitably fails fully. (Most likely once the crack reaches one of the frost plugs) I think it'd be a waste of money and time to rebuild the engine with this block. Oh and I found a rust hole on the side pocket of the trunk, which someone covered up with sealant goop, a piece of number plate and bodywork filler. Fun times. So far for every issue we fix we just find a new one that is arguably worse.
    • I have not found this no. I put one back on a couple days ago with no drama. I agree they are tight, but no need to remove anything.
    • That is gates blue racing belt
    • Anyone found gates blue racing to be extremely tight/ almost impossible to install without moving the exhaust gear
    • Hello am apex am new here and also thanks for helping registering the forum
