  • Replies 46
Do you plan on keeping the car after you have your full licence? If not maybe it is better to wait. Then you can get a turbo car and the world is your oyster. Turbocharged power is as good as sex. The advantage of turbocharging is that the pleasure comes whenever you put your foot down. The result of putting your foot down with a woman is a kick in the ballsack.
Edited by *LOACH*
https://www.sau.com.au/forums/topic/418483-fun-cars/#findComment-6721669
Do you plan on keeping the car after you have your full licence? If not maybe it is just better to wait. Then you can get a turbo car and the world is your oyster. Turbocharged power is as good as sex, the advantage of turbos is that the pleasure comes whenever you put foot your down. Putting your foot down with a woman results with a kick in the ballsack.
THIS X1000
https://www.sau.com.au/forums/topic/418483-fun-cars/#findComment-6721672
What about an MX5 or a hot hatch like a Renault Clio Sport?
Hell yeah, ol skool mx5 with the pop up headlights, nice set of fat jap lightweight wheels and some neg camber.
Touge to the MAX!!!!
https://www.sau.com.au/forums/topic/418483-fun-cars/#findComment-6722259
Definetly want something reliable, therfore newer. Need a non turbo as im still a bit under 2 yrs off fulls and my bro will take this car when i move onto a turbo skyline.
Basically something light and fun. Prefer coupe as well
MX5 is perfect besides the 2 seater hassle.
Is the Beemer myth real or not? As too the expansive parts and such?
Edited by ML73ZR
https://www.sau.com.au/forums/topic/418483-fun-cars/#findComment-6723040
n/a supra, vtec/engine swapped civics, teggy vti-r, prelude vti-r, 3s-ge sw20 mr2, aw11 mr2 if you can find one, manual mivec fto, silver/blacktop 4a-ge levin/trueno.
That'd be my shortlist.
Or you've got the classic trashed q's silvia etc
https://www.sau.com.au/forums/topic/418483-fun-cars/#findComment-6723152
My 2c, buy a te/tf crossflow 6 powered cortina backed by the single rail borgwarner 4 speed box.... Extractors exhaust inlet manifold Holley decent tires will see a 14 second 1/4 enough to walk alot of stockish turbo imports and older v8s.
Bigger cam solid lifters valve springs port work better clutch minispool 90/10 shocks and say hello to a low 13 second (possible 12 second) p plate "legal" street car.
(There is a guy running in the 11s on an NA [no nitrous, turbo/supercharger] cross flow powered td cortina in qld... http://m.youtube.com/#/watch?v=ACor769AAoA&desktop_uri=%2Fwatch%3Fv%3DACor769AAoA&gl=GB)
Sky's the limit with them bro, just watch for chassis rail rust and bad shells
Edited by Captain Natro
https://www.sau.com.au/forums/topic/418483-fun-cars/#findComment-6725050
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
