So today i parked my car in the usual spot at work and did not move it for 9ish hours. I got in my car this afternoon to move it around the back of my work (as i'm storing it in the workshop because we're getting a f*ck load of rain/flood) and all of a sudden my revs drop from 2k to 0 and the car stalls. I naturally thought "What the f*ck?" then i started the car again, drive 10 metres then it cuts again. So now i'm starting to get worried.. started the car again and drove another 15m into the workshop then turned it off.
When i first lost revs i also got a few lights come up from what i remember it was battery and a few others. Popped the bonnet and had a look around checked the belts to see if they were very loose but they were tight and everything else seemed ok. I am really not sure what's happened, we have got a hell of a lot of rain up here in the last 48 hours i'm just wondering if my car has just died because it's been driven 20m in the last 2 days and hasn't warmed up at all since it's been left in the cold the whole time.
Any feedback would be good, hopefully i get in it tomorrow and it starts fine and i have no problems.
https://www.sau.com.au/forums/topic/418485-strange-experience-today/
id guess its fuel or air related - something to do with the fuel pump or your intake.
just some ideas:
that stalling sounds very similar to when the fuel pump has no power, it doesnt pressurise the injection manifold, the manifold has enough fuel in there to start and run for a while then eventually dies. but then you shouldnt be able to restart the car afterwards.... which would indicate a possible faulty pump. (or no fuel in the tank)
Or if your MAF sensor plug was disconnected, similar result...
or an inlet leak of some kind could do that.
i'd check the CAI hasnt popped off somewhere between the MAF and the plenum, or maybe a hose connected to the plenum (EGR or crankcase breather)
worst comes to worst, plugging a scantool up should give you a better idea
it will be a crank angle sensor or one of the cam shaft sensors. get it to a diag tool and it will give you the code, then look it up on google it will tell you what sensor it is. happened to me and it was my camshaft left hand side. about a $300 fix all up
I had a similar issue to this a while back, went to take off from the lights a few times then BAM! Felt like the engine died, hazards went on... fail. I checked a few things similar to what was suggested, disconnected the battery, reconnected, seemed to work fine after that :S Not sure if it was 100% the same however.
I would look at the cam/crank sensor too.. a failed fuel pump or air leak will generally cause it to stumble and run horrible for a bit before it stalls.. Check the codes.. it should have stored something if it is a failed Crank/Cam sensor.
Ok so i checked the MAF and intake this morning when i got to work and it all seems tight, started it up and let it get warm. Drove it around same as i did yesterday and had no problems at all. So i guess it's all sweet, if i have the problem again i'll get a scan tool on it.
Thanks for the advice
I think the engine light came on, to be honest i just thought to myself ahhh shit then tried starting the car again i didn't take note of exactly which lights came on. Yes Tony i used the clutch appropriately haha, thanks mate it's fine up here now haven't had rain since yesterday afternoon it's nice and sunny now with a bit of cloud so i reckon it's gone further south. My boss was blocked in this morning had trees down over his driveway and smashed windows from the wind.. got pretty crazy out where he is.
I have a set of Camshaft sensors, ordered from the US last may but took an age to get here and needed the car working to hit the snow fields so took it to Nissan Artarmon and had them replace the fault sensor at nissan pricing.
think they cost around $70 each ill have to double check, but cheaper than from Nissan direct
Cheers
James
Hey James, for future reference which shop did you buy the cam sensors from? Did a bit of a search on the net and couldn't seem to find anywhere. By the way, i drove the car home after work and had no problems at all. Really is a mystery as to what happened, i still think somehow it's because of the cold over the last 3 days.
    • Would this not be the same for the exhaust you've posted up?  If your exhaust volume and emissions are fine, why does the brand of pipe matter?
    • The issue is more the fact that there is inspectors that deal with japanese cars a lot and they might know what a real Mines pipe looks like. And then they're gonna get antsy and not pass your car. But I'd have to talk to one of them about this, because you know as well as me that it's just a damn pipe and it effectively doesn't do anything. As I need to have my GT2860s and my exhaust setup (and the increase in HP) TÜV'd anyways maybe they can just correct the entry in the papers or assign a badge to the front pipe. I'm no expert either though, will inquire about this.     Thanks for the insight. Not sure if having a custom made pipe is good or not. Will find out in due time I suppose. Would be kind of funny if this was made in Germany though.
    • See this is a really tricky topic as technically the same rules apply to all cars but for cars but there is a difference. If you want to modify a car like the Skyline which never existed here you have a bit more freedom as they do not adhere to EU specs anyway. Any modification you do has to be in dividually checked anyway so as long as one of the inspectors think it's ok and within the TÜV ruleset you can get stuff like a top secret rear diffuser put in your papers. Which frankly would need a shitload of tests and certificates for EU spec cars, like a 2010 BMW M3 for example. But if you DO run these tests and all tests come out ok (safety stuff for the most part) there is no problem running such a part legally. It's just way too expensive to do for a single person on one car. The most touchy parts are emissions related mods, like an exhaust, turbos, air intakes. If it makes noise or alters the carbon emissions it's essentially illegal until you prove it's not. Meaning it doesn't exceed noise limits or have worse carbon emissions. I'd say for hoses if you replace them same same it doesn't matter what material they are or what brand you use. Same for nuts and bolts usually, they won't go and specifically check that your water hoses and some bolts are 100% OEM parts, that is nonsense.
    • What I don't understand here is that it mentions using a sealant. So either way you're ruining the inside of the tire and making a huge mess to clean up. Why not just do that, air it back up to spec, then take it all off and put it back in the car? Also, why not just include a plug kit that's not garbage?
    • What a f**king weener. I have worked in Gary, IN. At the time there were more gun deaths each night there than almost anywhere else in the world. Still not a reason to be afraid. 95% of people from your part of the world only have 3 teeth left from when you were addicted to meth, and now you're perpetually wrecked by Fentanyl. The only saving grace is that most of you didn't vote for Trumpler. Speaking of which, I'm off to the oval office right now. Got to relieve my bowels.
