Hey guys,
Well the old girl has given up compression on no.6.
1989 model. Imported/complied in 1999. Gunmetal grey.
90,000km on the motor.
'94 model engine so has long drive crank.
Timing belt/tensioners/water pump (n1) and oil pump (n1) done as well
HKS oil cooler kit with filter relocation
Tomei sump baffle
Profec B spec 2 electronic boost controller
Nismo cluster (so can't be 100% on kms however in very good condition)
Nismo rear subframe (stiffer bushes)
Nismo billet flywheel and button clutch (balanced) Plenty of life left - only done 5000kms
Nismo shocks and springs (firm without being teeth chattering)
Newish genuine radiator
R33 GTR brembos all round with plenty of pad
Wedsport 17" lightweight wheels. (unsure of exact model but can chase up) -so light you can juggle them
Bee R front pipe
Full exhaust
Sounds the goods (less so now that she's low on comp)
Sure i've forgotten lots but it'll come to me.
Body quite good. Has had a respray since coming to Aus. Few scratches and what not but she's 24 years old!
Interior good. 1 tiny mark on dash (not a bubble)
Nismo gear knob
Momo wheel
GPS based alarm with satellite tracking
Sony head unit
Has had oil/filter/coolant/fuel filter etc in last 200kms.
Heaps of hoses replaced under the inlet manifold and also replaced water fittings and other little bits and pieces.
No leaks.
Has rego till November 2013.
Its a great car that just needs the motor freshening up and will be a joy for a new owner.
If the price is right i can include a a forged bottom end that is ready to be put together and lots of spares. (power fc, turbos etc)
Will get some pics up this weekend.
$16000 happy to negotiate with serious people. May seem a bit dearer than the rest but at least you know what your'e gettting.
Located: Castle Hill
Cheers
Luke
0422 729 679
Edited by piranha
  • Replies 48
Yeh I realise that.
But if you buy a 32 gtr in any condition with a std engine you really have to budget in a rebuild.
Best to know before you buy I reckon.
Like I said happy to negotiate and listen to any offers.
Its not a rusty bucket with a basketcase of problems like all the other ones selling for really cheap.
You make a good point with the shell being rust free, but regardless it's a blown engine worth nothing which you can keep. And you won't find anyone paying 16k for a rolling shell and as much as your negotiable, I'd be guessing a thousand bux if that is all you'll negotiate. I know you just want to try make most the money you paid back but there was an immac rolling shell r33 GTR registrable sell for like 5k which was just missing running gear. I'm just being realistic with you.
I can do it as a rolling shell for a lot less if someone wants it that way.
It would be a but of a shame to see it stripped and tracked though.
Anyway, see what happens. If not it will go in storage till I can get some time to work on it
I had a car that did that. I pulled the head popped the sump pushed out number 6 piston, and re
Ringed and honed it. Since then the car is running perfect compression for years. Have to set the right tolerances but !
Will do $15k as is including power fc and hand controller.
Still trying to work out a price without motor.
Can also do cheaper without wheels.
I'm talking with a couple people about the shell.
I will have to wait and see if they want the loom in it.
As soon as I know something i'll let you know.
Cheers
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
