Helicoil Expert Required For Ej20E Timing Tensioner Rethread.
Hi guys in a very desperate situation.
Was replacing the water pump on the girlfriends 99 RX EJ201 N/A impreza and when I attempted to reassemble the timing belt etc. the thread on the tensioner pulled some of the alloy out with the bolt. :@
My biggest dilemma is I am more than capable at doing the majority of mechanical work, but I have never attempted a heli-coil and nor do I have the equipment.
Any one able to help out or suggest someone fairly low cost. I'm not concerned if you are not a qualified mechanic as I am neither just someone that knows what they are doing.
The bolt diameter is 10mm.
The car is located in Runcorn
Please PM me or sms 0415 054 949.
Edited by PickleNick
I wouldn't recommend helicoiling it as it's a fairly important bolt. I've had a couple pull the threads our after their 2nd or 3rd belt change, that whole piece under the aircon pump unbolts and can be changed with a second hand item.
actually helicoiling is quite common in aluminium, as the helicoil in the aluminium is actually stronger than just a thread in aluminium. Something to do with the surface area of the helicoil on the aluminium.
Its not all that hard to do really, go buy a helicoil pack, it gives you a tap, you drill the hole out to the size it specifies, tap the hole with the provided tap and then wind the helicoil in and snap the little tang off once its in as far as you want it.
In saying that, if you can change the part as said above id be more inclined to do that as you want to ensure its all drilled and tapped square, and its alot harder to do that when its on the car compared to a drill press or mill.
+1 to the above post, helicoil is piss easy, drill, tap, coil, snap the end off. Can be difficult to do while in an engine bay, get it out of the car so you can drill square
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
