Ive had a noise from the rear of the car which has been there for a couple of years, but most recently has become loud enough to be a concern.
Its hard to describe it exactly, it is loudest at around 90km/hr , its pulsing low dull roar sound, im wondering wether its a wheel bearing, cheap crap tyres or a diff thats going, ive jacked the car up and the back wheels are solid.
one point relevent or not, whilst hard acceleration in second i get massive wheel spin which sometimes starts to grip and shake the driveline, and also last time at drags it started gripping during the burnout too,
so question is ... what does a dying diff sound like? how can i distinquish the problem without wasting money...
https://www.sau.com.au/forums/topic/418598-noise-from-the-rear/
Dying duffs are more whiney droaney than dull roar. Wheel bearings can roar. Your car is old enough that they could be dead. They are quite good at being stuffed in Skylines without letting on too much.
If you have an original viscous diff with the listed mods above, I'm not at all surprised that you get wheelsping and variable performance from your diff. The VLSD is poor enough with standard power let alone with a lot more. You will benefit from a decent mech diff for drags anyway, so start looking even if the rest of your existing diff is fine.
You should look into new diff mounts and subframe mounts (new Whiteline poly or harder ruber Nismo stuff for street comfort, solid mounts for stiffest location but with poor road noise isolation).
Hoping its the wheel bearings, guess they should be replaced anyway, likely to be the originals..
I will look into the diff mounts and subframe mounts cause there is some movements happening at very low speed on a rough bumpy drive way..
So thinking bout diffs, id be after an improvement without any driveability issues like locking up wheels when doing a turn or harsh/rough with street driving, so whilst i will do some research , whats your opinion on a suitable diff ?
lastly, would i benefit from a slight step up in the diff ratio to make my gears a touch longer, eg couple hundred rpms and what ratio would that be?
It will be a wheel bearing that noise, they give a similar noise to 4wd tyres, I have a rear wheel bearing noise in my car but won't do anything unless it sounds terrible. It has a roll over noise usually. Jack you car up, drive it to te problem speed and put a stethoscope on the hubs and that will tell you. Btw keep your head low while checking lol
  On 27/01/2013 at 4:13 AM, GTSBoy said:
A 1-way mech diff from Nismo, Cusco etc would be the best way. Will give you more positive drive at the drags and on the street without causing clunks and extra understeer etc etc.
I was under the impression you could only get 1.5 or 2's from Nismo?
yeah im not sure, ive jacked the wheels up and theres zero movement, i guess they could be dry or worn still, the tyres i used to have on the front ( some hero crap) got so noisey i had to replace them, so the back ones are same hero crap tyres so im thinking its an even bet between tyres and bearings, the noise is pretty much always there but loudest on the freeway.
My Nismo was 2 way when i got it but i got it adjusted to 1.5 way, the housings on the Nismo and Cusco (I assume selected models) can be rotated to change the ramps etc.....
The noise you describe mark is kind of what i had when i put the solid locking rings in the rear, it went away when i changed my diff so i can only assume one of the axle bearings in the diff were shot?
As for the shudder on launch that sounds like axle tramp? Mine went away when i did the locking rings etc (mostly anyway)
i have heard tyres that are not even chunky (normal sports tyres) be noisy like a bearing but it seems rare, you could have a noisy bearing for the next 100000km and it wont fail, and as you go faster it will emit a louder noise, special if its a lubrication issue as it gets hot. you wont get play unless the bearing is on its way out, but wear and tear and they get noisy. if it was a soild rear axel its hard to check for play due long solid axel hanging off the end, lucky its not a dirty old holden :)
if its one bearing and not both try cornering hard left or right. If it is the cause, lifting the weight off the worn side will alleviate the noise. I currently have a worn bearing and this is how i was able to determine which side and that it was not a diff noise.
    • That still isn't a lot to go on. I don't have a Y50 Fuga Head Unit wiring diagram. I can say that a lot of nissans of that age shared head unit plugs, so if you are in Australia something like this would probably help: https://aerpro.com/app091# You plug that into the car loom, then either plug the head unit ISO into that (if it has ISO), or you buy and ISO adapter harness that you wire in. Bit of stuffing around, but once you have ISO its easy to change things in future.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
