  • Replies 53
ok guys. this is to stop now or I'll take a hacksaw to this thread. there was a question asked and only really one person has answered. NOT GOOD ENOUGH!
If you guys need to take stabs at each other then take it to the wastland.
No wonder people arn't coming to drag combat... the would be too bloody scared. :D
wreckhead: Your little private message didnt impress me.
YOU are the one who has done nothing but talk yourself up yet you have failed to show at any of the recent events so you have no call trying to refer to us as nerdy keyboard warriors.
Loose your attitude, or do us all a favour and piss off because nobody is impressed.
please blitz dont talk anymore, i was at WSID racing when 2rismo and Buster were there, i think that they are 1 of only a few people who get out there and actually race their cars, and really i dont care if your impressed or not, im not here to pleasure you or this forum. im here to buy and sell stuff and help out with any info i can.
So Blitz turn off your computer and head out in the sun and get yourself tan or something casue it think your cheesy white skin has kept you awake for a few nights to many.
:P thats got to be the most pathetic retort I have ever read.
got coherent sentences?
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
