Urgent Borrow: Trolley Jack + Jack Stands
Need to swap my exhaust for a stock zorst and I have already got an extension on my EPA notice. I have basically Sunday, Monday, Tuesday to get it swapped out and tested. I am free all those days.
Trouble is I don't yet have jack and stands. Have only come across dodgy looking ones and will keep looking for something suitable for purchasing. On that note I have been thinking of ratchet Kincrome stands if anyone has any comments on that and somewhere they sell the damn things! also looking for a decent trolley jack (low profile) possibly light as well.
Please reach out a bit for me and help me get this done :D
0400 346 056
[email protected]
49A Winfield Rd, Balwyn North
  • Replies 104
If you know someone with a Costco membership, get their low profile jack.
Grab some stands from Supercheap Auto. A Skyline isn't super heavy so pretty much any of them will do.
Yeah I wish I knew someone with COSTCO Membership I want that Arcan jack. I was going to buy it off Ebay for ~$200 but if I can't borrow a jack off someone i'll need to buy something before and Ebay jack will arrive.
Got it sorted, thanks guys. For anyone who reads this far. Still looking for Arcan Jack and kincrome ratchet stands strong enough to lift skyline if anyone comes across either in a shop or goes to Costco let me know!
Using the arcan jack today it was great in terms of lifting the car easily even with only half the handle on BUT We couldn't jack it very high. I think it's max height is too low. Anyone else find this? After jacking it up to full height we could only get one 'click' up the ratchet stands.
Car sounds weird now. So quiet to me but i'm not sure it's quiet enough for EPA test. It's a stock catback. Is that all I need to do to pass?
http://tinypic.com/m/fuwgp4/1
^ video ^
Edited by jukic.j
At first in the garage it seemed loud and so I took it for a drive and I was like :woot: is my engine even on?
It even felt more responsive... I was like is a smaller exhaust... better???!?! but then I gave it a bit of stick and no pull :verymad:
Naughty stock exhaust :domokun:
Has anyone noticed this sense of responsiveness with a smaller exhaust? I'm not sure if it's placebo but changing between gears seems quicker and smoother kinda.
I'd say it's loud cause it's in the garage man.
Bigger exhaust is only a benifit when you are running under boost. Just tootling round off boost a big exhaust actually robs some power but who cares about that ;)
Your rear wheels are like 10cm off the ground in one of those pics, is that the max height of the jack?
With my jack (full sized, not a little aluminium low profile) I have to remember to close my boot before I jack it up off the diff, so that my boot doesn't hit the roof of the garage :P
Edit: Mods, I'd also be removing your address out of the first post of this thread.
Yeah the wheels are a few cm off the ground in that picture. Clearance was good from the rear but I think the front was more difficult because of how far back you have to put the jack stands could only get one click on the ratchet stands and it was a little low. That being said you could just jack it up full height, stand it. Then roll the jack onto some sort of solid platform that it wont roll off and jack it up a bit more as someone said. That's something I could live with.
Don't worry about the address i'm in the process of moving out or I wouldn't have been so liberal about it :P
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
