im looking to buy a factory stereo trim panel to suit series 1 v35 sedan. it only needs the a/c buttons and board installed,
dont need the head unit, am/fm/disc buttons, or pocket/screen as i'll be recycling my own
either in adelaide or requiring freight here
ta
im looking for one in black/charcoal, not silver
FYI, unless the sedan is different to the coupe, the a/c board is integrated with the stereo unit.
the crawler just pointed out an issue i wasnt aware of. all i heard was that the 2 trim panels werent interchangeable
trying to avoid buying an aftermarket panel for a different kind of install... if i can keep the a/c board working by tucking a board from the original stereo behind the dash... i will
Must be a sedan panel in charcoal colour
Thanks Sleek but any scratches or marks outside of the factory stereo buttons are not wanted.
Edited by Deep Dish V35
Nah mate, you CAN'T separate the a/c board from the stereo - it is all one piece. Apparently it has been achieved before, but you literally need to cut the circuit board, reroute circuitry tracks, and all sorts - and the success rate is extremely small, even for expert circuit board builders.
You need to source a stand alone a/c controller like the one that comes with the dual din kit.
Do you have a series 1 or 2?
http://www.ebay.com/itm/JDM-NISSAN-INFINITI-DUAL-ZONE-A-C-CONTROLLER-G35-2005-2007-/170949933521?pt=US_Car_Audio_Video_Dashboard_Installation_Kits&hash=item27cd68f9d1&vxp=mtr
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
