Hay guys, i am looking at getting a 180sx with the following modes:
White 180SX with black roof and black bonnet
Tuned on caltex E85 for 256rwkws and 685nm
Blacktop SR20DET
RB25 gearbox conversion
Custom tailshaft and gearbox crossmember
HKS GT2835 Turbo kit including Highmount Manifold, braidied lines and external wastegate
850cc injectors
Power FC with Hand controller
Huge FMIC and aluminium piping
Blitz Exhaust
Ceramic Clutch
Body Kit
Vented headlight cover
Clear side indicator lenses
Sony Head unit
Nardi Steering Wheel
Sports Gearknob
Velo fixed back racing seat
Racing Logic Coil overs and Camber Tops
Front and Rear strut braces
blitz EBC
doluck floor brace
bright white headlight globes
Bosch 040 fuel pump
Volk SE37 Wheels 17 x 8.5 and 17 x 9.5 (Forged. Very expensive and very light)
Bridgestone Adrenalin tyres all round
5 stud conversion
R33 brakes and Ferrodo race brake pads
Hydro Handbrake
Alloy overflow tank
Tomei two way Mechanical Diff
Tein Tie rods, rack arms and spacers
alloy Steering Knuckle
Adjustable Castor Rods
Pineapples (cradle bushes)
WHITELINE Sway Bars (Front and Rear)
z32 afm
catch can
heater and air conditioner work 100%
It now has a idle issue, they have changed a whole bunch of sensors and other bits and pieces but still has the idle issue once car is WARMED up.
Could it possibly be the power FC or other sensor to do with motor temp or water temp?
All information on it would be gold before i decide to go out and buy it!
https://www.sau.com.au/forums/topic/418628-180sx-idle-issue/
    • If you don't touch the CAS, then you're fine.
    • Yeah, my moulds and seals are 32 years old now. I think I will continue to not use a pressure washer on it.
    • I hear the old "I'd never use a pressure washer on my motorbike" BS in the dirtbike community too.  The only people that have had a problem from using a pressure washer on anything are the people that aren't using them properly.  If you hold the wand any more than 45 cms away from pretty much anything (radiators, wiring connectors, paint, etc) you aren't going to cause any damage.  We've had detailers wreck moulds and seals on cars at work before and the only reason why is they held the pressure washer too close and on the one spot for too long.  If you have 5% more brain power than a detailer then you know not to not do that and you'll never have a problem.
    • I'm pretty much healed up post surgery so I spent another almost full day out in the shed re-arranging everything to make room for all of the shit that I've taken off the car.  I need to get everything off the floor and away from the car for when I start making a massive mess stripping off the remaining body deadener and then for the the painting process.  Almost got the shed to a point now where I feel I can actually start working on the car again (clean shed clean mind or something!).  Almost 11 years of accumulated car parts, building supplies, tools, junk, etc have taken a long time to get in some sort of order again!  Most stuff is now boxed up and in the back shed if it's not car related.  Most people would still be horrified walking into my shed but it's significantly better than it was before!   For those that saw my separate post the other day, yeah I ordered one.... This version- I convinced myself to stop being a clown, wake up to yourself and realise it will take you 5 weeks to make one by which stage you're over working on the car again...  Maybe I am getting on top of my "mental ailments" and making smarter choices.... $1450 delivered which will take my miserable half-dutch arse a few days to get over having spent that much!  If I don't have a use for it straight away after my car is off it I might even see if there is a "rental market" for them.  See if anyone wants to hire it for a period of time.  $25 a week or something like that.  I'll worry about that when my car is actually ready to come off it though as that might be a while away!! There's now no excuses now for not ending up with an underside you could eat off! Away for kids sport the next few weekends so hopefully can get the rotisserie assembled ready to go for the car to go straight on it the next available weekend.
    • I always use my Karcher, but it's only a little one that I picked up from Supercheap  The only issue I ever had with a pressure washer was when I was a kid cleaning coaches, they had a hi-po industrial sized petrol jobbie that would strip paint if you got to close I saying this, we have a fairly high power washer at work with a diesel powered heater that sprays water at about 60°c, it works great for removing old wax and road grime on the underbody after some foam cannon action, albeit from a "stand off" distance of a few feet
