  • Replies 65
I didnt plan to hit an island and I consider myself an alright driver, just was very inexperianced, didnt know the capabilities of the car, imagine what would have happened if I was behind of a 200rwkw+ car, I dont think I would be here right now is what I think.
yeh man, i am taking the advice aye, cause some of it is actually worth reading but some of it they are saying is just sh*t, so why bother, so yeh aw well,
and this isnt really for u!! but i aint AUSSIE, who ever said i was!!
Hrmm.. that was sorta me I believe?
2) Dude.. I aint australian, even I cant understand what in the hell you are talking about half of the time.. see quote.. Perhaps this is the reason why people are telling you to goto uni?
I didnt think that automatically means I'm calling you an aussie. *sighs* Anyhow, your post seems to have magically lost all the weirdnesss/slangs (watever you want to call it).. so its all good. :P
no one plans to kill themselves.....
I second that. :D
Ditto. I still crash'd a Pajero, even though I have been behind the wheel of a 400rwkw+ race car... long enough. Any shmuck can drive... Not every one can stop in the wet... :D
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
