  • Replies 63
For those intending to enter the terms and conditions, as well as payment details are available at
http://www.autosalon.org/orderform.asp
If I have read it correctly the cost to enter as a club display is $50 each, but it will cost you more if you want to enter the DYNO CHALLENGE or SPL/ dB DRAG RACING CHALLENGE.
To enter as a club we must have at least 6 cars. (It may pay to have a few in backup as well)
As the club name is critical to how we are grouped it’s important we all use the same name, hence I suggest we use "Skylines Australia" and not abbreviate it to SAU. We will also need power, so if we will need to pay an extra $60.
PS Whats the chance of all enterants getting together to plan this. We can use my place if its OK with all of you. As time is running short, I would sugest we meet either this weekend or next weekend. What are your thoughts?
Guest Miss_Nismo
**** da police .... if we don't take our cars out at all, or sell them and buy falcodores instead, then they win. Yes getting defected sucks, but we can't not live our lives in fear. And as for the 'there will be a defect station here, here and here' .... just look at what DIDN'T happen at drift day (which was supposedly going to be defect city) - I only saw 1 copper all the way home - and he had pulled over a commondore :)
Yeah and if we don't protect ourselves, and get our cars defected, they are also winning. It's a win-win sito for those guys.
By avoiding getting defected, I'm just avoiding a lot of head ****s.
Anyway, I might enter still, just depends on the status of the skyline at the time :cheers:
Guest Miss_Nismo
Excellent Paul :P We've got to have the GT-R represented under the SAU banner!
Having a 'Skylines Australia' display without the almighty GT-R would be a bit like drinking zero-alcohol beer :cheers:
Edit: The only bummer is you wouldn't be able to do a dyno run on the Boost Worx dyno :)  Unless Shaun did the remove shaft option?
Here's the updated list of "potential" entrants:
4door_Sleeper (R33 GTS25t 4dr)
whatsisname (R33 GTS25t)
Envisage (R34 GT-t)
cell (R34 GT-t)
Nightcrawler (S15 200SX)
Steve (R33 GTS25t)
skipppy (R33 GTS25t 4dr)
Clint32 (R32 GTS-t)
Pawley (R33 GT-R)
MattR (S14 200SX)
Miss Nismo (R32 obviously not worth mentioning)
:headspin:
Shutdown
Envisage (R34 GT-t)
cell (R34 GT-t)
Steve (R33 GTS25t)
Clint32 (R32 GTS-t)
Pawley (R33 GT-R)
MattR (S14 200SX)
Miss Nismo (R32 GTS-t *worth mentioning, as it has a special engine*)
Hi Guys
Just got the word that my car is unlikely to be out of the spray shop in time for the show. :-(
This means that there is room for another 4 door :-)
I am still happy to help organise/coordinate this if it’s needed (as I am the one who started this whole thing anyway)
If there is a need for those entering to get together and plan it (or just meet and go for a cruise and talk) my place is still available.
Remember to get your entries filled in soon as there is a late fee for those who register in the last week.
PM me if you have any further questions.
If someone wants to run with this (and help 4door) that would be great! If need be I'll do it, even though I'm a tad busy atm.
Damn it! I just realised that Autosalon is on the same weekend that 'I' want to do go-karting. Bummer ;)
I'll post up a new thread for people to give a, 'yes I am 100% entering AS'
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
