Hi guys,
I have been having grief with my speedo for some time now, it gets stuck at ~60kmh intermittently (about 10% of the time).
Someone once posted that the Odo plunger may be the culprit and if I wiggle it it does make it work "better", as did thumping the top of the dash.
Ive had the dash and cluster out many times, hit it with contact cleaner, lubed up the Odo gears, etc etc but nothing seems to fix it.
Now after some anger management issues it no longer has a odo plunger to wiggle and gets stuck on, well, Zero about 90% of the time.
I have bought a replacement cluster (top - sorry for blur) but many of the globes dont work, it doesnt have a Airbag wire like mine does, and it only shows half speed.
It's an auto cluster (PRNDL) but was in a manual vehicle so Im assuming someone did a "jumper" switch to halve the speed shown.
I havent been able to find the correct jumper to fix it, and Im not sure I want to due to the Airbag wire / globes issue.
These are all things I didnt notice when mine was in the car and after reading many posts about how "there's no difference between clusters".
I was always sceptical, in that I believed theer was the half / doubling issue, but wasnt aware of the Airbag wire difference.
So, does anyone know how I can fix either, or get the speed right, and what the airbag wire does / if it is necessary / transferrable, and what else to look for?
thanks
https://www.sau.com.au/forums/topic/418674-r33-series-15-auto-cluster/
I cant remember if I bothered.
I put LEDs in mine when I swapped so I have spares I can try.
I was more concerned with the speed reading half what i was doing, and the Airbag wire, neither of which I figured would be globe related.
Edited by Sinesweep
    • I had never actually looked into it, but aren't onboard compressors a thing in trucks?
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
