hi, I have got some r32, r33 engine parts for sale. also some rb30.
rb20det crossover pipe x 3
rb25det crossover pipe x 2
rb30 crossover pipe x 2
rb20det stock bov x3
rb25det stock bov x 2
rb25det air compressor bracket has been soda blasted
rb25det hicas p/steer pump
rb25det non hicas p/steer pump
rb30e na camshaft gc
rb30 na starter motor x2 (auto and manual are the same)
rb20det starter motor
rb30 stock cam gear
rb25det sII stock cam gears
rb25det p/steer reserviour
rb25det polution canister
rb25det cas bracket
rb20det stock dump pipe x 2
rb25det stock dump pipe x 1
rb25det oil pump
rb25det oil filter cooler sandwich plate x2
rb20/25det stock exhaust manifold x2
rb20/25det exhaust manifold heat shield
holden rb30 rocker covers
tridon rb30 thermostat. used for maybe a week max
rb25det neo cam covers
internal fuel pump r32/r33? jecs
rb20/25det thermostat housing/lower hose to block pipe x 3
rb alternator slider bracket x2
rb30na heat shield
factory vl turbo A8 pistons and rods x6
rb30na exhaust manifold down to cat
p/steer pump brackets
neo engine cover bracket
rb25det neo rocker covers
rb25det bare intake manifold $15
rb30 sump
r33 rb25det cooler hoses
stock sII rb25det injectors
Stock sII rb25det coilpacks
Call Jamie. 0433 559 722. pick up from rothwell, brisbane northside 4022
Edited by gold-3lt
https://www.sau.com.au/forums/topic/418685-skyline-parts-rb20detrb25detrb30/
  • 3 weeks later...
  • 1 month later...
  • 1 month later...
  • 1 month later...
    • I love the undertray, especially the flappy bit for easier access for serving I'm thinking of fabing up one at work for the MX5 while I still have access to the metal shop at work with a guillotine and press brake Whilst removing the plastic undertray on the MX5 isn't to hard, I love the idea of a 2 bolt flap as opposed to removing the whole thing
    • Great thank you for that. Yeah that is the bumper and spoiler it still has i just hadn't heard of it being referred to as a aero form bumper before. Really appreciate your help.
    • A little progress; I took the opportunity of an oil change to take a sample for oil analysis, will be interesting to see how it was treated for its first 125,000klm (I know how it has been treated since :rofl:) I went with 5w40 and will see what that does for oil pressure at higher revs. Also fitted the Z1 front undertray....a little more sturdy than the plastic factory one (although I suspect it won't stop a tree stump ) Nicest thing about it really is the 2 bolt "service panel"....a gift to the oil changer compared to removing 14 bolts holding the factory tray.
    • I think a scissor lift is better/faster in most cases, but I guess it does obstruct access to the centre of the car? BTW I weighed the quick jack. 3.5 tonne model is 50kg for each side. So yes, portable, but not with one finger
    • Not a huge update because still waiting for some fittings for the intake. But I did corner weigh the car, its enough to make a GTR driver cry at 1163kg (race ready except no fuel)  Sorry about the terrible pics but I think they are readable With 70kg driver
