Hey guys,
So a few months back I had a grinding metal on metal noise come from my clutch when pushing it to the floor.
Gearbox was pulled out, cleaned, thrust bearing replaced and the noise dissapeared until now! It's returned.
So the noise comes when pressing the clutch pedal to the floor. It's a metal on metal noise not the normal bearing noise from a thrust bearing. The noise happens when first driving the car and after heating it up and driving around for a while it stops.
Anther thing to note is you can feel the grinding in my gearstick when changing gears as well as in the foot pedal.
Ideas?
https://www.sau.com.au/forums/topic/418725-clutch-noise-returns/
Ideas?
sounds pretty standard but when you say they pulled out the box did they take the casing off and inspect the internal bearings?
From my understand they told me they pulled the box out and changed the thrust bearing. They didn't change the spigot.. Is the spigot behind the casing?
What internal bearings are there?
Spigot is in the end of the crank..the input shaft sits inside it.
post-22242-0-54793300-1359365883.txt
bearing on the input shaft, some in the rear part and in the center plate. I have pulled apart a few rb20 boxes that sounded similar to what you describe and they all had a failed bearing somewhere.. Pretty larbour intensive to fix so wont be cheap
Edited by battery
Is it possible to do this work yourself or do you have to have a fair understanding in pulling a gearbox apart?
Like the other guys said replace the spigot first and see how you go, if you took it to a workshop complaining about the noise then they should have changed it while the box was out.
  • 4 weeks later...
Guess I will be taking you up on the offer Mat to do it over a few drinks on a weekend.
Thanks for the info once again guys.
Workshop has since closed down so nothing I can do about it now.
i think we know why they closed down....
sorry to hear mani.
hope you get it sorted.
  • 1 month later...
    • Most of the industry in North America either runs on Siemens or Allen Bradley. I have two redundant S7-1500's on my desk right next to me for simulation. Siemens has been losing ground though since Stuxnet, as cybersecurity is a big thing. In my line of work that is federally regulated, you must by law have a cybersecurity management program in place and its audited and inspected every so often.  I work with Emerson PLC's daily (RX3i's) and have done large biogas/refinery projects with their DCS's. Their PLC's are somewhat OK minus the way they do PLC redundancy (You have to download on both PLC's separately every time you make a change )  As for their DCS's... you'll be limited financially first before anything else stops you. Costs are exorbiant at roughly 10x what it would cost you to do with any other system (e.g AB PAC).  1990's, those suckers are brand new haha! Kraft-Heinz (An old client when I use to work for an ESP) still runs Siemens TI505 PLC's from the mid 80's. Ohh how I don't miss working with those... you could only do a certain number of online downloads until it's "Change" buffer would be full and you would then need to go offline to do a full download. There was no warning of when this was coming up and it generally would happen when you would go in at 2am to make changes before production -_-.
    • Unfortunately, not only is that not the case, one of the main "Selling points" of safety over comms is they clearly state in writing that there's no need to segregate safety networks from non-safety networks. It always gets intermingled with everything else on an ICS/OT network.
    • Hello. I have an a31 cefiro but since I am in Turkey we have a CA20S engine. I did some research. Then I found that I can swap with a ca18 but when I heard that it has the similar substructure as the s13. I thought I can swap with an sr20 because the sr20 was used with the s13. So can I easily swap the sr20 on my cefiro or is it difficult?
    • I used to love stock take. I used to take f**k of a lot of stock. /Rodney Rude.
