Too low, too loud and worn tyres up the inside of the rears.
They had a special stick to measure ride height, and used an iphone to measure db at 3000 rpm. Tyres failed a visual inspection and they also noticed the diff had leaked some fluid around the drainage plug. Whoopee doop.
The problem is that on top of the minor faults noted (and the $325 fine) I need to produce a roadworthy certificate within a month. This will require a mountain of standard parts (in roadworthy condition) that I haven't owned nor even seen at wreckers, for years.
https://www.sau.com.au/forums/topic/418734-d-d-d-defected/#findComment-6726173
I'm in a terrible quandary actually.
I have no real idea which things will/won't pass RWC without engineering. Similarly, I have no idea what an engineer will pass/fail, or how much they will want for their time.
There are a bunch of smallish jobs (the list really adds up quickly though) that I definitely need for RWC, and that's before I start attending to the many backyard modifications like carbys, exhaust, suspension, wheels, brakes, etc.
Ill hit a mechanic and find out what exactly they'll want changed/engineered, but I don't see a RWC happening in the 28 day time limit for anything less than a staggering sum of money.
Probably my realistic options are beg a scrutiniser for club plates and buy a daily, find a seriously crooked mechanic who'll do a dodgy RWC, or sell/part out.
I can temporarily swap some parts from another project for the purposes of the RWC, but run the risk of getting defected again when I change back to modified.
https://www.sau.com.au/forums/topic/418734-d-d-d-defected/#findComment-6726848
Measuring the sound at 3k rpm is a load of shit, as the rpm they test for differs depending on year and make.
But hey,
They make it up as they go, cant do much about it.
Find a DECENT car club, get some plates,
enjoy cheap rego and heavily reduced insurance costs.
Or ask Super Dragger if you can rego it in his name in NSW haha.
https://www.sau.com.au/forums/topic/418734-d-d-d-defected/#findComment-6726937
Lol! I am actually a NSW boy originally - maybe I need to head home for a bit!
Adz do I need a RWC even for club reg? I thought the club scrutiniser got the final say on whether a car was eligible for club rego.
Although Im not bothered about putting the car on club reg, shelling out for a daily driver is a bit of a pain. I need to be able to get to work quickly at all kinds of odd hours, and have limited parking around home.
https://www.sau.com.au/forums/topic/418734-d-d-d-defected/#findComment-6727060
First up I am going to hit a mechanic and find out exactly what needs doing for a RWC.
Then Ill run the numbers and decide if it's worth it. I've still got full rego till 11 2013!
Also, I need to meet a club scrutiniser and find out how far the car is off club rego.
https://www.sau.com.au/forums/topic/418734-d-d-d-defected/#findComment-6727993
In a strange twist, I called Vic Roads and asked them about my car.
They said that the officer who issued the defect to me, has not contacted Vic Roads to list the car as defected. As far as they were concerned they have nothing at all on file to say my car is currently defective, and as such they have no plans to cancel my registration at the end of the 28 day notice period.
So, if I were to turn up at Vic Roads tomorrow with a RWC, their response would be 'huh, what's this for?'
The guy at Vic Roads recommended to obey the conditions of the defect notice and turn up with the defect notice, RWC and car, so they can check that all the work required on the notice as been completed. I argued that according to the Vic Roads website I only need to bring the car in if there is a defect notice on the windscreen, (there is a odd loophole that if you replace the windscreen for RWC they don't need to see the car.) However the Vic Roads guy was not convinced.
I'd be interested to see what would happen if neither the officer or I ever supply details of the defect to Vic Roads. I have a strong suspicion that the car would simply remain registered. :devil:
https://www.sau.com.au/forums/topic/418734-d-d-d-defected/#findComment-6744683
that sucks man,
what i have done in the past, was change the licence plate. i had a full list of defects, did the same as you rang up and they had no idea about them, so i just changed my plates and yea sweet. ended up but got pulled over again about a month or two later and defected again, that time it stuck.
but it worked for me at the time
https://www.sau.com.au/forums/topic/418734-d-d-d-defected/#findComment-6745740
  On 10/02/2013 at 11:06 PM, ydr030 said:
that sucks man,
Actually, I didn't quite read your post right.
So to get this straight, you got defected, Vic Roads/RTA didn't know of any such defection, so you declared your plates lost/stolen etc and got plates with new letters and numbers. When the police pulled you up again you weren't in defected Skyline ABC-123 you were in not defected Skyline XYZ-789. It worked because the police defect only lists registration number, not VIN or engine number.
That's genius: if I try it on, Ill definitely be cleaning up my car some anyway. I'd hate to get redefected again. It sucks.
https://www.sau.com.au/forums/topic/418734-d-d-d-defected/#findComment-6746450
