By base I presume you mean idle?
It will depend on your cams, and if you want it to idle nice... and not stall out when the aircon comes on.
I set 20 degrees at a 900 RPM idle, and advance to 22-23 degrees below 900 rpm, and also in the next load cell up. When the aircon goes on, or electrical load increases, the engine produces more torque with the ignition advance and it will auto-stabilise back around 900 again.
RB25's advance the intake cam at idle which improves vacuum and decreases lobe seperation making the idle smoother. You'll find that auto's vs manuals have differing idle advance settings too, to accomodate for the load of being at idle in gear with a torque convertor slipping but on the verge of engaging. Im pretty sure the RB30 manuals are 15 as per the manual, and 20 for the autos. Rb25's with VCT change the rules by making the idle more stable by advancing the intake cam. It is then retarded off idle and advanced again for top end power.
Yes base timing at idle is what i was talking, mine seems to like 15 degrees rather than 20, using the rb26 head, with some decent cams.
need to plug in consult and lock it then set to whatever the ecu is reading... can never assume. Its common for the factory ecu to swing 5 degrees at idle and if you dont lock it its very easy to get it wrong... base ignition is the root of many engine issues... i reckon it is one of the most common owner induced mistakes we have to rectify for customers....
Running autronic sm4.
Just wondering why some rb motors are 15degrees and some 20?
If you running an SM4 you can run delta ignition control. It also has an rpm rate varaible so that you can apply positive or negative ignition changes based on the direction of rpm change - not just under or overspeed rpm event. Great ECU btw - my favorite. Who's pushing the buttons?
Ah, yes i seen that function, would be great for cars without idle solenoid.
After some fiddling with settings, i got mine running well using the stock solenoid.
Its great for cars with idle control valves also. You will find that most manufactures run both an idle control valve and delta ignition control. Engine speed responds alot faster to a change ignition request than a change in idle air flow....
PM sent..
    • This could be sold and shipped to the US for many gold pieces. RMS has no say in that. Ask various Western Sydney inhabitants how it works.
    • Ha ha ha, mine loves to spend, all on the dogs (they're our kids, and her spending would likely rival that of some people raising children!) the only benefit is, her spending is tax deductible as she runs a business in the dog industry 😛 The above all means she can spend race car budget quicker than I can. 😛 That and a lot of the things I want are very expensive, and I can be a bit "you want how much for that?!" And at other times overly impulsive. Or I start the w days of research, get to day 1.5 and get really annoyed that no one will advertise actual specifics and it's just marketting BS and I go "well, now I don't want anything to do with that now!" Also I hate paying lots of money for something I can make from $50 in materials. Then I get the shits halfway through making things and wonder why others who just buy parts have more fun... 😛
    • Their 240Z with the RB26 would be a real nice thing to have in a garage to come out for an occasional weekend cruise It's such a cool thing in so many ways Sadly, we have a blue 240Z shell that I walk past every day, just sitting outside a shed at work, it has been slowly disintegrating and falling apart into the ground for the last few years, the owner cannot be found, and I am unable to "claim it" I've been told by work and the RMS, the rust in the body is excessive though, and it has had most of the salvageable stuff, like panels, trim and switch gear stripped off it over the last year or two, work keeps threatening to put it in one of our metal scrap bins, I wish they did though, as it makes Mark sad walking past it
    • Good tips, I like it! 😂😂 My wife is a LOT more frugal than me so it's only me we need to worry about! A splurge to her is buying 2 pairs of socks in one visit at Kmart!
    • Haha, the appropriate response to the question "Is this new?" is "I've had this for a while.". With the unspoken small print that a while may be the time since this morning or five years ago   And to be fair I learned that from the best, i.e. my wife. Because it goes both ways.
