SKYLINE R32/RB20 Parts:
*Flywheel $50
*RB20 turbo with lines, actuator and elbow-minimal shaft play $180
*inlet manifold $30
*alternator $50
*starter motor $50
*Engine wiring loom $100
*RB20det computer $120
*stock cat $10
*injector resistor packs X2 $5 each
*injector rail with fpr and stock injectors X2 $15 each
*r32 stock intercooler $30
*exhaust manifold $60
*rubber intake pipe $10
*throttle body $20
*tps $15
*airflow meter green label $60
*cam covers $make offer$
*timing/cam pulley cover $offers$
*ac compressor $30
*clutch slave cylinder $10
*rb20 gearbox cross member $20
*rb20 viscous fan hub with rb30 fan $30
*2x after market steering wheels $make offer$
Best contacting me on 0420986545.
Located Adelaide hills.
May post depending on item.
Negotiable on some of the parts.
What would you take for the afm,ecu and engine wiring loom posted to nsw 2259? I have a silvertop rb20 in my passage but its running all the redtop engine management so i have to change it all out.
Feel free to send me a msg 0424108110 or just repky on here
Thanks
Will suss our price on postage and get intouch with u. All that stuff maybe sold. Waiting to here back from someone else today.
  • 3 weeks later...
*Flywheel $50
*RB20 turbo with actuator and elbow-minimal shaft play $120 PRICE DROP
*inlet manifold $30
*alternator $50-SOLD
*starter motor $50_SOLD
*Engine wiring loom $100-SOLD
*RB20det computer $120-SOLD
*stock cat $10
*exhaust manifold $60-SOLD
*throttle body $20-SOLD
*tps $15-SOLD
*airflow meter green label $60-SOLD
*ac compressor $30-SOLD
Have lots of other 20 parts lying around. if after anything just txt me.
0420986545.
  • 1 month later...
have following parts still.
*Flywheel $50
*stock cat $10
0420986545.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
