33_GOD Posted January 29, 2013 Share Posted January 29, 2013 Does anyone know what this is and know where it's properly installed too?? If someone could help would be great! Pics attached Very urgent as need car ASAP Cheers guys! Link to comment https://www.sau.com.au/forums/topic/418775-help-needed-what-is-this-part-and-where-to-hook-up-to/ Share on other sites More sharing options...
Duncan Posted January 29, 2013 Share Posted January 29, 2013 That is the carbon cannister that helps reduce unburned fuel emissions Link to comment https://www.sau.com.au/forums/topic/418775-help-needed-what-is-this-part-and-where-to-hook-up-to/#findComment-6726990 Share on other sites More sharing options...
33_GOD Posted January 29, 2013 Author Share Posted January 29, 2013 Ok thanks but where do the 3 hoses connect to. Link to comment https://www.sau.com.au/forums/topic/418775-help-needed-what-is-this-part-and-where-to-hook-up-to/#findComment-6727112 Share on other sites More sharing options...
Dose Pipe Sutututu Posted January 29, 2013 Share Posted January 29, 2013 Just remove the unit, those compliance charcoal canisters are ugly Link to comment https://www.sau.com.au/forums/topic/418775-help-needed-what-is-this-part-and-where-to-hook-up-to/#findComment-6727678 Share on other sites More sharing options...
GTSBoy Posted January 29, 2013 Share Posted January 29, 2013 Just remove the unit, those compliance charcoal canisters are ugly That's your recommendation to someone who lives in Melbourne? Really? Link to comment https://www.sau.com.au/forums/topic/418775-help-needed-what-is-this-part-and-where-to-hook-up-to/#findComment-6727877 Share on other sites More sharing options...
Dose Pipe Sutututu Posted January 30, 2013 Share Posted January 30, 2013 That's your recommendation to someone who lives in Melbourne? Really? I am assuming the stock one is still there, I have seen many skylines with the stock charcoal canister looped into the aftermarket charcoal canister. I was suggesting to remove that fugly compliance one and only run the stock one. Link to comment https://www.sau.com.au/forums/topic/418775-help-needed-what-is-this-part-and-where-to-hook-up-to/#findComment-6728891 Share on other sites More sharing options...
GTSBoy Posted January 30, 2013 Share Posted January 30, 2013 I've never seen a compliance charcoal canister. Ever. Can you show me a picture of one? Link to comment https://www.sau.com.au/forums/topic/418775-help-needed-what-is-this-part-and-where-to-hook-up-to/#findComment-6728961 Share on other sites More sharing options...
Dose Pipe Sutututu Posted January 31, 2013 Share Posted January 31, 2013 That massive one in the top pic, I've seen a few R33 with that looped back into the stock one. Mine was the same, took it off and just used the stock R33 OEM one. The stock one sits bolt next to the LHS passenger headlight, has a small u shaped hose which connects to the fuel tank. THe other 2 goes to the plenum. Link to comment https://www.sau.com.au/forums/topic/418775-help-needed-what-is-this-part-and-where-to-hook-up-to/#findComment-6729981 Share on other sites More sharing options...
GTSBoy Posted January 31, 2013 Share Posted January 31, 2013 I didn't even open his pictures. I just assumed it was a shot of the factory location (glancing at the thumbnails). When did they start fitting those to incoming cars? As I said, I've never seen one, and I've been under the bonnets of hundreds of Skylines over the years. Link to comment https://www.sau.com.au/forums/topic/418775-help-needed-what-is-this-part-and-where-to-hook-up-to/#findComment-6729999 Share on other sites More sharing options...
89CAL Posted January 31, 2013 Share Posted January 31, 2013 (edited) Theres 2 Vac lines going nowhere in the second photo that look the right length? usually there are labels on the top. From memory vent goes to fuel tank vent, purge goes to throttle body (or IC side of plenum) boost feed and the other one goes to a plenum boost/vac feed. Those last 2 might be wrong way round but gives you some idea anyway. Stock charcol canister is mounted at the front on a bracket with 2 bolts holding it to the crossbrace for the radiator (Top) Edited January 31, 2013 by 89CAL Link to comment https://www.sau.com.au/forums/topic/418775-help-needed-what-is-this-part-and-where-to-hook-up-to/#findComment-6730123 Share on other sites More sharing options...
Dose Pipe Sutututu Posted January 31, 2013 Share Posted January 31, 2013 I didn't even open his pictures. I just assumed it was a shot of the factory location (glancing at the thumbnails). When did they start fitting those to incoming cars? As I said, I've never seen one, and I've been under the bonnets of hundreds of Skylines over the years. No idea, but every so often I see one. Especially fresh ones at dealers, I believe most people just rip them out, bin them and use the stock one. Link to comment https://www.sau.com.au/forums/topic/418775-help-needed-what-is-this-part-and-where-to-hook-up-to/#findComment-6730309 Share on other sites More sharing options...
Yeedogga Posted February 1, 2013 Share Posted February 1, 2013 No idea, but every so often I see one. Especially fresh ones at dealers, I believe most people just rip them out, bin them and use the stock one. Yep, mine had one. Was a sooper shonky job too. Was the first thing I ripped out. Who needs two charcoal canisters? Link to comment https://www.sau.com.au/forums/topic/418775-help-needed-what-is-this-part-and-where-to-hook-up-to/#findComment-6732065 Share on other sites More sharing options...
MrStabby Posted February 1, 2013 Share Posted February 1, 2013 Who needs two charcoal canisters? That's an interesting question with an obvious answer.... Link to comment https://www.sau.com.au/forums/topic/418775-help-needed-what-is-this-part-and-where-to-hook-up-to/#findComment-6732486 Share on other sites More sharing options...
33_GOD Posted February 3, 2013 Author Share Posted February 3, 2013 So I can rip out the one in the pic ( I.e the big black fugly one with the 3 hoses)Also i can't find the OEM canister at the front that u guys are talking about, could someone post up a pic of it and how to re direct all of the hoses into the that one so I can remove this black piece of shit! Cheers guys! Link to comment https://www.sau.com.au/forums/topic/418775-help-needed-what-is-this-part-and-where-to-hook-up-to/#findComment-6734076 Share on other sites More sharing options...
33_GOD Posted February 3, 2013 Author Share Posted February 3, 2013 Anyone? Link to comment https://www.sau.com.au/forums/topic/418775-help-needed-what-is-this-part-and-where-to-hook-up-to/#findComment-6734100 Share on other sites More sharing options...
GTSBoy Posted February 3, 2013 Share Posted February 3, 2013 Looks the same. Probably slightly smaller. Sits against inside of radiator support panel between rad and headlights. If it's not there, don't rip out the big one. Consider relocating it to where the original one was. Link to comment https://www.sau.com.au/forums/topic/418775-help-needed-what-is-this-part-and-where-to-hook-up-to/#findComment-6734372 Share on other sites More sharing options...
