That's your recommendation to someone who lives in Melbourne? Really?
I am assuming the stock one is still there, I have seen many skylines with the stock charcoal canister looped into the aftermarket charcoal canister.
I was suggesting to remove that fugly compliance one and only run the stock one.
That massive one in the top pic, I've seen a few R33 with that looped back into the stock one. Mine was the same, took it off and just used the stock R33 OEM one.
The stock one sits bolt next to the LHS passenger headlight, has a small u shaped hose which connects to the fuel tank. THe other 2 goes to the plenum.
I didn't even open his pictures. I just assumed it was a shot of the factory location (glancing at the thumbnails). When did they start fitting those to incoming cars? As I said, I've never seen one, and I've been under the bonnets of hundreds of Skylines over the years.
Theres 2 Vac lines going nowhere in the second photo that look the right length? usually there are labels on the top. From memory vent goes to fuel tank vent, purge goes to throttle body (or IC side of plenum) boost feed and the other one goes to a plenum boost/vac feed. Those last 2 might be wrong way round but gives you some idea anyway.
Stock charcol canister is mounted at the front on a bracket with 2 bolts holding it to the crossbrace for the radiator (Top)
Edited by 89CAL
No idea, but every so often I see one. Especially fresh ones at dealers, I believe most people just rip them out, bin them and use the stock one.
Yep, mine had one. Was a sooper shonky job too. Was the first thing I ripped out. Who needs two charcoal canisters?
So I can rip out the one in the pic ( I.e the big black fugly one with the 3 hoses)Also i can't find the OEM canister at the front that u guys are talking about, could someone post up a pic of it and how to re direct all of the hoses into the that one so I can remove this black piece of shit!
Cheers guys!
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
