Okay about a month ago I bought a 93 r32 gtst type m..
Mods are:
T04e high mount
FMIC
Yellow jacket coil packs
550cc injectors
Walboro in tank fuel pump
Tial waste gate w/screamer
HKS bov (will be putting stock BOV plumbed back shortly)
Mines ECU
Adjustable coilovers
Just want an estimate of kw from the wheels ill be getting? Only a rough estimate obviously. AFTER A TUNE!
Edited by Zrobe
https://www.sau.com.au/forums/topic/418780-power-to-expect-from-these-mods/
OK, so the power will be limited by one of three things.
1) The turbo.
2) The injectors.
3) The ECU.
Start with the easy one. Your Mines ECU was a waste of money. It can't be tuned (if the EEPROM has been glued in). If the chip isn't glued in, at least you can convert it to Nistune. But then you can do that with a standard ECU anyway. (And, yes, I assume the Mines ECU was already in there when you bought it and therefore it's not your doing, but nevertheless). Worse, the Mines ECU is not well suited to running in Australia. Intended to run on Japanese 100 octane and tend to be fairly over-advanced. Can ping an engine to death pretty quickly in the wrong circumstances.
The injectors will do no more than 300rwkW, give or take a bit. But that it plenty, and probably a lot more than you'll get out of a TO4e on an RB20 anyway.
I suggest you scan through the RB20 dyno thread and see whether someone else has posted up some results with that engine/turbo combo. The rest of the mod list really doesn't matter except to determine whether the fuel and ignition and so on are good enough for the power level.
1) The turbo.
2) The injectors.
3) The ECU.
Mines ECU wasn't glued I had a new chip put in. Yeah bit of lag with that turbo haha.. As long as I'm over about 250 260rwkw ill be stoked.
Depending on what spec T04e it actually is - will depend if you'll get there.
There was something like 30 variants, as they are from the 1970s... So lots of wheels/housing combo's around. I think you'll be struggling to get 260rwkw, and it'll be laggy.
Yeah I wouldn't have a single clue to what spec it is.. Kicks in at around 3600
I suggest getting rid of the turbo and getting one suited for the 2L motor, then get a nistune or an aftermarket ECU as the mine ECU won't be tunable and will probably ping/do all sorts of weird shit as soon as you start putting any decent boost into it, could even pop the motor if it is highly advanced.
I had a mines ECU in a car I bought about 5 years back, the previous owner had retarded the base timing back as far as it went just to stop it pinging, it also ran so rich that it went off the AFR scale when on full load, below 9:1, basically they are just crap and not suited in anyway for what you have.
there are a thousand T04E variants as stated. not all are bad and plenty of people have had them work without a drama. kicking in at 3600 is fine if thats when it starts to pull hard id be happy.
find out what T04E it is and go from there. hopefully its one of the common ones.
I recommend changing the ECU for a nistune at minimum and you will probably be limited by injectors before anything else.
My tuner said it will be tuned to whatever is in the tank.. i said i didnt think that was possible.. Anyway I'm over talking about my ECU, if my tuner has lied well.. I ain't going back...
Lol, is there a way by found out what variant is it WITHOUT pulling it apart? Probably a stupid question but I'm here to learn..
No factory ECU can tune/trim the fuel on the run, which is what he said he has been told... Or perhaps it was bad describing on his behalf.
What about the chip he put in? Can that make a difference to the pinging.. This is f**ked lol
People need to start reading ALL the posts.
OP says Mines ECU chip is not glued in and in fact another chip has been put in there. Therefore it is possible to tune that ECU, either by the shitful 90s method of burning EEPROMS, or by putting in a Nistune board.
/ ECU problem
Turbo still an open issue.
Yeah and read the subsqeuent one where he states it will adjust to whatever fuel is in the tank - that is simply untrue (and this is the part we are talking about).
It is a SINGLE tune option. You set it for say 98 octane - it is set for good.
Your current setup does not...
1. Adjust when there is detonation
2. Adjust for other fuel types in the tank
3. Adjust for changes to boost levels
Well I've spoken to him again.. He said its no lie? I'm going to get him explain to me properly how he did it.. I'm only taking his word for it and is a family friend.. So I don't see any point in him lying. I'm just going to punch him in the head if my car pings out lol
No, you see, I read that as meaning he will tune it to whatever is in the tank. Which is kind of what you have to do, no?
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
