Cheers for that, I'll definitely consider the ID1000s, if the price difference is only a couple of hundred I may take the gamble and go with the ASNU. They are essentially the same Bosch injector but with a modified printle cap for better atomisation. I think one of the members here is actually the distributor, so there may be discounts to be had on the website price.
i have fiveomotorsport injectors, big company in America that just make injectors, I have 1000cc in my 34gtr and they are fine im running 324kw and the highest ive seen them at are 55% but high impedance so I believe you have to get rid of/ bypass the resistor box, also they are a bit cheaper than the ID 1000cc.
Rather than sales dribble, we would prefer some proof. Can you supply some detailed information of the differences between your injectors and the standard Bosch ev14's, and why they are worth the extra price?
Why did you modify the spray pattern, was there a design flaw you were trying to engineer out? Any information you can give is appreciated, we love technical responses. :)
Sorry for borrowing your thread. I just bought id2000 for my r33 gtr and i am wondering what to do whit the resistor box is there any easy way to hook my new injectors in or do i need to solder the wiring? I have a autronic sm4 pnp ecu if that makes any difference.
I assume you just ditch the injector box and directly wire them to the Autronic. Perhaps you should check with your tuner...
Shame the thread got cleaned, I read an interesting rebuttal this morning... ;)
http://www.injectordynamics.com/BullshitEpidemic.html
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
