Hi all,
Just joined, so do forgive me if posting a 'hello' post is not allowed or if I'm doing this in the wrong section.
Anyway I joined as I'm a Sydney-sider looking to buy an R32 GT-R and (in addition to everything I've already read here) any advice is more than welcome.
I've also seen several cars for sale here but the threads have since gone cold, so I'm hoping to be around for the next one that pops up and grabs my attention.
Mechatronic engineer - F1 aficionado - former F3 mechanic - motorsport purist.
Cheers,
James.
https://www.sau.com.au/forums/topic/418823-new-member/
  • Replies 41
Thanks gents,
Either is fine really but if modified (be it slightly or worked) it has to be clean with appropriate documentation.
Will primarily be a track car for a few outings per year but that doesn't mean I want to be doing any form of major rework (unless the price is right).
https://www.sau.com.au/forums/topic/418823-new-member/#findComment-6727437
does it have to be a 32?
and a gtr?
mark is selling his 33, very cheap for what it is.
have seen it in the flesh, car is meticulous.
http://www.skylinesaustralia.com/forums/topic/418712-r33-gtst-2530-500hp/
Doesn't need to be a 32, but I don't want a 33 (nothing personal, just don't like the look of them), and a 34 is most likely out of my budget so I'm left with 32. I do have a sweet spot for their look though, I must say.
GT-R is preferred, yes.
https://www.sau.com.au/forums/topic/418823-new-member/#findComment-6727489
Sweet spot for the 32, that is.
https://www.sau.com.au/forums/topic/418823-new-member/#findComment-6727494
Been playing with the idea of stepping into a 32gtr over the 34gtt.
Still early days and might not end up doing it.
Cheaper to modify by a long shot! Just get Benji to help you pick one :ph34r:
https://www.sau.com.au/forums/topic/418823-new-member/#findComment-6727956
He'll be my #1 info source.
Good information isn't far away.
Yep I'll soon let you know the originality of the panel gaps, whether all the seams are in tact, which panels have copped a fresh lick of paint, and a quick look under the car will show whether the car has had structural damage etc.
https://www.sau.com.au/forums/topic/418823-new-member/#findComment-6728000
Its the only gap you will be seeing Benji :P
Now make yourself useful and go help James find a nice GTR!
https://www.sau.com.au/forums/topic/418823-new-member/#findComment-6728023
mines all original, with champaign paint, yellow engine bay, and 26/30....
https://www.sau.com.au/forums/topic/418823-new-member/#findComment-6728143
sweet jebus i can't recommend mark's 33 enough
and what's wrong with having a boat? YARR WE CAN SAIL THE SEAS AND PLUNDER BOOTY
That would require an offshore powerboat license! That is one quick boat!
https://www.sau.com.au/forums/topic/418823-new-member/#findComment-6728168
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
