hi all,, i have a 1990 r32 gtr, purchased with most of mods done by previous owner. when i brought the car i was told it was running 290atwkw on 17psi, with mods, which include, r34 gtr N1 turbos, hks cam gears, sard 800cc fuel rail, injectors to suit, walbro fuel pump, apexi pods, hks to intercooler plumbing and blow off valves, stock intercooler, ally radiator, has a full stainless apexi exhaust, and that all i can think of from memory.
i recently had the car in for some other work,minor stuff. but also got the car tuned to run e85, it came back running 294.9atwkw, at around 23psi
i qustioned the previous owner and he swears black and blue that it made 290kw when he owned it.
is this an average amount of power for mods and e85,
or is there something wrong with the car where its lost power, but ifso i thought the tuner would be able to pick up on this?
any help or thoughts would be great cheers. :yes:
https://www.sau.com.au/forums/topic/418826-right-power-for-mods/
hey sorry forget to add, it was tuned at the same place. but when i got it tuned on e85 it was in rwd as im having problems with front drivshaft. i did ask them to put fuse in for tune,,, but they didnt lol. when it was tuned the first time with previous owner it was in 4wd. both on same dyno from same place. im just abit confused..
no i didnt, because i just thought the previous owner must have bullshitted me. but i just spoke to im and he swears it made 290kw, im waiting on a pic of dyno slip. not sure anout injectors being maxed it has sard 800cc, didnt think they would be?
E85 is not a promised top end power increase, there are factors involved.
I bet you are not running 23psi @ 8000rpm, -7s (R34 N1s) and -9s (GT-SS) in just about every graph I have seen, fall over above 7000rpm to around 18psi by 8000rpm give/take as they are simply small turbos. Hence why they are so responsive.
The only user that's claimed a good 40rwkw gain (with 5-6psi), hasn't come close to running a MPH that remotely backs that up, jury is still out on that one :)
Splitting hairs - You'd probably expect to be around 300-320rwkw, but i say near enough - and check the midrange. That's where you should be looking on -7s/-9s
thanks for your input.. the dyno graph i have really doesnt show much, its a real basic graph. not really happy with that either, im more than happy with the power it has. just was confused abit and wasnt sure if the car could have lost power somewhere along the line, cheers
:yes:
You could check the exhaust for a restriction, make sure it doesn't have any in-built restrictors (lots of Jap exhausts have 2.5" restrictors before mufflers, internally).
Otherwise try get the old graph and the new one overlaid. That'd give you a good idea as well.
But definately get a boost read out, i would be surprised if there is 23psi above 7500rpm
Ah and have a look @ that - 18psi in the top end :merli:
Although it was never running 23psi mate - It only gets to 20psi and immediately falls. It should hold 20psi a bit longer before it falls over IMO. Which would give you a meatier mid range.
    • Holy smokes brother. If you get there before me, let me know if that was manageable with a hone. I still haven't done anything with mine and probably won't until I get the car MOT'd later this year so that I have another 2 years to do what ever needs to be done. I am at 86.5 now so at least I have the 0.5mm to go up from where I am, but that means new pistons at the very least. Honestly, might consider a stroker at that point.  Cheers
    • It's the adhesive holding the ceramic wheel to the shaft the fails on 90% of them.
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
