Nearly anything is possible, if you have the money. However, the amount of money you'd need to do this, you won't earn in 2 years.
In short; Buy a GTR when off your provisional license.
No GTR Skyline ever came as a 2WD/RWD car. Part of why they're a lot more expensive then their GTS-T/GT-T counterparts.
https://www.sau.com.au/forums/topic/418849-quick-question/#findComment-6728276
thanks,
that's all I needed to know, it just occurred to me that it might be cheaper but clearly not.
thanks for taking the time to reply mate as clearly never been into it all too much although have worked in an industrial engineer shop since 15 so I'm not hopeless just with exact models and makes can be convertered on a specific skyline so I figured here would be a place to ask. forgive me for thinking that.
https://www.sau.com.au/forums/topic/418849-quick-question/#findComment-6728722
Just read, read, read. You'll learn all you need to know from this website. Chances are that if anyone has ever thought of a question, you'll be able to search and find the answer here.
Nothing against you personally, but a lot of people will see the question you asked as the cardinal sin of skyline ownership. Bright side is that your knowledge base will only improve from here.
https://www.sau.com.au/forums/topic/418849-quick-question/#findComment-6729146
Incorrect, see C10 and C110 Skyilne GT-Rs from the 1969 - 1973 :P
OP, as suggested, read read read, and read some more. The more information you have the more informed choices you will make.
Lucky for you that your first car is an R34. It will teach you car control and how vehicle reacts to driver inputs and conditions (skid pan and track days). Don't worry about the non-turbo aspect, you have plenty of power for a p-plater.
I still have my first car, my R31 Skyline, which is supposed to be my daily. Your N/A R34 will be a good daily, the NEO6 is pretty economical. You can buy a GT-R later and have your R34 as a run around :).
https://www.sau.com.au/forums/topic/418849-quick-question/#findComment-6750679
Not worth it. If you want more power and keep the shell and just drop a 25NEODET into it. Apart from that it isn't worth the cash to through a GTR widebody and other mods. If you want a twin turbo but can't afford a 34 GTR when off P's just get a 33 or even a 32.
https://www.sau.com.au/forums/topic/418849-quick-question/#findComment-6750690
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
